    Junior Member LetemSpin1's Avatar
    Poolesville, Maryland
    2000 trans am ws6
    dreaded SQUEAK!!!
    ok so ive had this squeak for about 2-3 months now and spent almost $300 to fix it and its still there! ive replaced both tensioners, both idler pullies, and both belts and while its gotten better its still there! after cold start up its very noticeable esp. when on the gas. after full warm up and about 30mins-1hr of driving it goes away. any ides of what it could be? ps pump, alt, water pump?
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    What brand belt did you use?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Does it squeak when you are parked?
    Dealing Powder ntimid8r7's Avatar
    Sep 2008
    Saint Cloud,FL
    1994 Z28 MQBM
    2001 SS #1629 LPM
    take your belt off and spin them by hand. my bet is the alternator. can you tell which side it is coming from?
    www.fquick.com/ntimid8r7
    www.cccfonline.com
    Triple H Coating
    Specializing in Powder and Ceramic Coating
    steve@triplehcoating.com
    www.triplehcoating.com
    old timer blue02Z's Avatar
    2002 Z28
    could be water pump, i bet
    Royal pain in the.... Phantom2kz's Avatar
    savannah, ga
    2001 Z-28 A4 NBM
    2002 35th anni SS M6#1696
    poss water pump or gasket leaking on to belt
    it is possible for P/S pully to be on too far,or not on enough ,that will cause problems.
    check from under car for leakage from WP gaskets/weephole.......dex-cool leaves a nice pink trail to follow.
    Member km346's Avatar
    Nov 2008
    masssaaechuuuseettes
    1998 hardtop SS
    Quote Originally Posted by ntimid8r7 View Post
    +1 i wouldn't have replaced a thing till i spun each pulley by hand.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    gatorback belts are excellent for stopping undiagnosed or undiagnosable belts squeaks
  1. Help: LS6 intake and the dreaded EGR :(
    By JoshuaGrooms83 in forum External Engine
    Last Post: 02-21-2011, 12:58 AM
  2. The dreaded One Wheel Wonder :-(
    By Intrepidman in forum General Help
    Last Post: 11-25-2010, 08:50 AM
  3. Dreaded Low coolant
    By gnomee in forum General Help
    Last Post: 02-19-2010, 02:21 PM
  4. Gm's Dreaded 10-bolt Time Bomb !
    By Z ROADSTER in forum Almost Anything Goes
    Last Post: 06-20-2008, 03:35 PM
  5. plugs and wires... the dreaded time arives
    By MaxPlusTen in forum LT1
    Last Post: 10-29-2007, 09:02 AM
