Thread: 98 camaro wiper problem
01-29-2009, 11:31 AM #1Junior Member
- May 2007
- illinois
OK in short I never had problems before a hood swap. Now afterwards my wipers when turned off go all the way to end of there stroke and stop in the middle of the windshield. Occasionally when turned off they will stop in the stock postion at the bottom. I replaced my hood and fender (dr) on the drivers side there is a finger size gap because the fender needs shimmed. When I first bought the car it was missing the under hood fuses box covers . So I thought maybe there was a wiper relay wet and causing this problem because I had a previous car do the same.. I ordered the covers and there isnt a relay labeled wipers on it and after looking around Im dumbfounded.. SO any advice greatly appreciated.
01-30-2009, 09:19 AM #2Junior Member
- May 2007
- illinois
no one?
01-30-2009, 11:44 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
Don't have the answer, but has got to be something that happened with the hood swap. The WIPER/WASH fuse inside the car in the main fuse box controls the motor and the wiper/wash switch. Only thing I can think of is maybe the motor electrical connector got knocked loose or something? According to my helms after turning the switch off the motor should still have power to put them in the park position. Sorry not much help....
01-30-2009, 01:23 PM #4Junior Member
- May 2007
- illinois
well that was better then nothing thanks..
01-30-2009, 02:31 PM #5
there is also a known issue with the control circuit board having bad solder joints. It was mostly limited to the truck line, but has shown up in few other vehicles as well.
01-30-2009, 06:07 PM #6Junior Member
- May 2007
- illinois
01-30-2009, 06:11 PM #7
its possible, on my dads suburban they would come on at random times or not at all, the problem affected the timing circuitry. IF you can find one that is know to be good give it a try. One more thing to check, is make sure any wires running to motor are hooked up and not crimped any where.
01-31-2009, 03:49 AM #8
we had talked about it some in this thread. Not sure if the original poster ever got his fixed. No update so I take it he hasn't yet. It seems odd that it would do it immediately after your hood install but I really see no way the hood install would cause your problem so I'm wondering if it's just a coincidence.
Help: Corvette wiper problem
By kingls1 in forum General HelpReplies: 4Last Post: 05-04-2014, 02:21 PM -
wiper problem! help?!
By ls1formula in forum General HelpReplies: 3Last Post: 07-18-2009, 02:44 PM -
Wiper problem
By One_Bad_TA in forum General HelpReplies: 9Last Post: 07-14-2009, 03:06 PM -
Wiper problem
By speedracer25f in forum General HelpReplies: 5Last Post: 05-20-2008, 10:33 AM -
Windshield Wiper Problem...
By The_Wretched in forum General HelpReplies: 3Last Post: 01-16-2008, 09:22 AM
