Results 1 to 15 of 15
Thread: With gear "break in".....
01-28-2009, 05:00 PM #1
Hey everyone I am going to get my 3.73 gears installed at the end of February and have to drive about 1 and a half to 2 hours away to get them installed. The guy that is installing them is very reputiable, but he is saying that I can drive straight home without stopping (for lunch maybe) and it won't harm the gears as long as i'm not flogging it......is this true will I be ok without stopping or will this be bad for the gears?~Chris
01-28-2009, 05:54 PM #2
You'll be OK !!!
01-29-2009, 01:12 PM #3Senior Member
- Feb 2006
- Orange County, NY
Drive about 500 miles being easy on them and have them rechecked and have the gear oil changed.
01-29-2009, 01:38 PM #4
Anyone else with any suggestions?
01-29-2009, 02:32 PM #5Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
The way we broke in my 9" was to run it on stands getting up to idle in 4th gear. Then shut the car down with the clutch in and listen for any noise. Next we took it out for a short 5-10 mile drive, keeping it easy on the throttle. Looked for leaks and made sure the casing was not to hot (also on test drive listen for noise). Let the car sit for about an hour and then pounded on it.
02-03-2009, 07:50 PM #6
anyone else with any suggestions or will i be ok to drive home?
02-03-2009, 09:00 PM #7
You'll be fine driving home. The only problem would be holding yourself back from driving it hard to try the new gears. Just baby it for about 250-500 miles and you'll be fine. That's what I did when I got 3.73. One of the best mods do date. Where are you getting the work done?
01 TA WS6: Volant CAI, custom ram-air baffle mod, custom borla, BMR-(SFC, LCA, LCA reloc, PH rod,TQ Arm), UMI swaybars, Eibach + Bilsteins, TTM Anth, SS brakelines, 160 deg therm, 3.73 gears, Yank 3400 stall, Yank Crsmbr, Hayden 24k, Trans Go shiftkit, ported TB + MAF...soon to be cam/heads
02-03-2009, 10:19 PM #8Impounded
- Oct 2007
- Beaver Dam KY
From what I have read you need to put some heat cycles on it before you beat on it, and when you stop let it cool all the way off.
02-04-2009, 05:07 AM #9Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
drain/change the fluid,visual inspection of the drained fluid will tell a lot about what's going on in there.
Is it just the gears that are being changed or are you changing posi/differential too?
02-04-2009, 07:55 AM #10
02-04-2009, 08:01 AM #11Member
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
i would stop on the way home to let the gears cool down. that might help with keeping them from making noise.
02-04-2009, 08:07 AM #12Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
visual examination of the drained fluid should then only show the gear break-in.Some gearsets are bronze phosfide coated to help break-in and there the fluid would show a 'bronzy' color,some are 'black/grey' coated with something to help break-in.Depending on the set you're using,initial drain should show some discolorization away from the normal transparent dark brown of the virgin fluid.
Only thing bad would be particles that are large enough to settle out quickly.
02-04-2009, 04:31 PM #132 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
for me I have always done a 3 step cool down. drive the car for 10-15 minutes, stop and let cool for at least an hour. do that 3 times. Then I take it easy for 500 miles varying my speed. Then I change my oil, then give her hell. Never had any "whining" issues when you properly break in your gears.
02-04-2009, 05:13 PM #14
Uhmmm... I always broke mine in a 1/4 mile at a time !!! LOL !!!
02-04-2009, 06:13 PM #15
Obama "Admits" to "Long Term Campaign" Against ISIS...
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 07-06-2015, 04:01 PM -
Anyone watch "Top Gear"
By clg82 in forum Almost Anything GoesReplies: 22Last Post: 10-25-2012, 09:31 AM -
Question: Need HIGH performance gear box "anybody"
By transamgreen in forum Manual TransmissionReplies: 1Last Post: 01-09-2010, 11:38 PM -
"GET TO THE CHOPPER": jail break from prison
By Soltakr in forum Almost Anything GoesReplies: 20Last Post: 02-26-2009, 06:03 AM -
SLP/GM Ring & Pinion, 4.10, Gear Set 7.5" & 7.625" Differential
By Stealthperf.com in forum Parts For Sale / TradeReplies: 1Last Post: 10-18-2006, 09:01 PM
