Results 1 to 1 of 1
01-28-2009, 10:10 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
30 No-Buck And Low-Buck Pontiac Mods
Economic Recovery-Pontiac StyleDouble Nuts Are Better
Do you want your stock front shocks to act somewhat like drag shocks? Screw a second nut to the top of each front shock until there's full thread contact on the shaft. Loosen the retaining nut at the rubber bushing until it contacts and locks against the nut you installed so that they can't loosen while racing. On launch, the front end will lift instantly to take up the slack on the shock shaft, and transfer weight much more quickly to improve traction instead of fighting the extension. This didn't work for a prominent F.A.S.T. racer because the shock to the chassis once the slack was taken up on the shock's shaft caused the rear tires to break loose. But remember, this type of racing requires a near-stock-size, bias-ply street tire.
Photo Gallery: 30 No-Buck And Low-Buck Pontiac Mods - High Performance Pontiac
More...
Almost $100 buck T-top mod
By ASh302 in forum Appearance SectionReplies: 22Last Post: 02-22-2015, 08:08 AM -
15 Cheap Mods - 15 No-Buck And Low-Buck Mods
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-05-2012, 04:20 PM -
the big buck
By jaslivers in forum Almost Anything GoesReplies: 21Last Post: 11-24-2008, 04:38 PM -
Best bang for buck mods
By Eric1987 in forum Camaro / SSReplies: 62Last Post: 10-22-2008, 01:24 PM -
Best LS1 Car 4 the Buck???
By drewk86 in forum Firebird / WS6Replies: 16Last Post: 08-31-2006, 09:20 AM
