Results 1 to 11 of 11
01-26-2009, 11:27 AM #1Member
- Jul 2007
- tx
black- 1994 camaro z28 a4
ppl running eibach 2'' lowering springs
what do u all think about them?how much do they run for? how does the car handle? any pictures? thanks in advance. any help is greatly appriciated
edit: my car is a 1994 camaro with some 18'' c5 zo6....would i have some rubbing isues?
01-26-2009, 11:32 AM #2
01-26-2009, 12:28 PM #3Member
- Jul 2007
- tx
what else would i need to install them?
01-26-2009, 12:31 PM #4
some diff shocks like koni but as far as install i really dont know, i know the rear is very easy to do, but you might have clearance issues, i did and i have 17X11 in the rear running 315's
01-26-2009, 12:33 PM #5Member
- Jul 2007
- tx
oh so im gona need some other shocks? my rims are 18x10 if im not mistaken and im running a 275 in the rear and a 255 in front
01-26-2009, 12:45 PM #6Senior Member
- Feb 2006
- Orange County, NY
Probably will need an adjustable panhard bar to center the rear.
01-26-2009, 12:48 PM #7
^yes forgot about that i still need one my right side rubs a little more lol
01-26-2009, 11:34 PM #8
The sportlines are just a little stiffer then stock springs(not the 1LE).
So bilsteins should be fine, IMO konis are overkill with the sportslines springs.
FYI,
You do know that with the sportlines you're basically riding on the bumpstops all the time, that's why the ride is rough (lack of suspension compression travel).
01-27-2009, 06:11 AM #9
01-27-2009, 06:36 AM #10
For me i would never do it again, everytime i took a turn meaning spirited driving i would have to watch out for any slight dips or bumps because the bottom of the car would scrape and sometimes bad enough were it was dangerous it would upset the cars handling and balance. This time i went with pro kits, not as bad and i have no issues with my 315's out back.
01-27-2009, 07:26 AM #11Crazy Canuck !
- Jun 2002
- Montreal, CANADA
been there, done that.
sportlines not only have very limited suspension travel, but the spring rates are low and progressive.
Having said that, you will run into 2 choices... bottom-out (if you try to dampen the springs properly) or overdamping the system to avoid bottoming out, making it even harsher... not allowing the springs to do its job.
In the end, I got rid of the springs and got ones that allowed for proper suspension car control.Eugenio_SS
Eibach Pro-kit Lowering springs
By MRM 01 in forum Suspension and HandlingReplies: 17Last Post: 12-08-2008, 09:45 AM -
anyone with eibach lowering springs
By stefos in forum Suspension and HandlingReplies: 10Last Post: 04-19-2007, 08:23 PM -
Eibach lowering springs fs
By Blksilvr in forum Parts For Sale / TradeReplies: 1Last Post: 10-25-2006, 12:46 PM -
98-02 Eibach Sportline Lowering Springs
By CWW17 in forum Parts For Sale / TradeReplies: 0Last Post: 10-12-2006, 07:37 PM
