    1998 Camaro SS
    Do i need new pushrods/springs with cam
    I know its a good idea to get new ones but will the stock pushrods and springs be ok with a 224/224 cam with .581/.581 lift on a 112 lsa?
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    You need springs at least. Pushrods are a good idea but not mandatory unless your gonna be spinning the engine over stock speeds.
    Stock springs are barely good enough to handle the stock lift. So those are required.
    Hardened pushrods are recommended with a stiffer spring because the stock pushrods bend easily.
    Lowered, HID's, tinted.
    Member side2000's Avatar
    md
    2000 camaro ss
    springs for sure. you're in there, stock pushrods are beat, so it's a might as well.
    1998 Camaro SS
    ok thanks guys. i was just hopin to save a few bucks bc everything for the ls1's are so expensive. the cheapest cam kit i could find was at texas-speed.com. its $700 with cam,pushrods,spring kit. and then i have to get a tune and thats gonna cost i dont know how much.
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Quote Originally Posted by jmatt07 View Post
    Unfortunately, it is always expensive to play with cars, and you don't want to skimp around on important things like the valvetrain. With that said, I have a similar cam 226/228 .585/.588 lsa 112 and I just did the cam, springs (Patriot golds only about 250 for everything), LS6 oil pump, and LS2 timing chain.
    A tune should cost you anywhere between 400-500. Best is to put things off just a little longer and do it right once, instead of risking a major problem happening while trying to save a few bucks.
  1. Question: 2006 z71 5.3 cam springs and pushrods
    By Kevinbird09 in forum GM Trucks
    Last Post: 05-06-2014, 05:35 PM
  2. For Sale: .::Ls1 Pushrods, Springs and Cam (OE/Stock)::.
    By ne0fiend in forum Parts For Sale / Trade
    Last Post: 08-12-2010, 04:54 PM
  3. looking for cam springs and pushrods
    By Russ2000ta in forum Parts Wanted / Trade
    Last Post: 01-24-2008, 03:07 PM
  4. 918 springs, Ti Ret and 7.4 pushrods
    By VENOMIZED03 in forum Parts For Sale / Trade
    Last Post: 10-12-2006, 10:49 AM
  5. LS6 Springs and pushrods, Full AC
    By LS144 in forum Parts For Sale / Trade
    Last Post: 08-27-2006, 07:52 PM
