Thread: Header bolts....leaks question
01-20-2009, 06:50 PM #1
This is for you guys with headers. Do you have any problems with the header bolts backing out and leaks?. I am considering the Coated pacesetters but I do not want to be tightening bolts and or replacing gaskets that leak every few hundred or thousand miles. What is your experience with them. I have been bolting on headers since the 70's and they can be a pain in the arse as far as leaks.....and yes you used to could buy some blackjacks for $49.00-$69.00 or some 1 7/8 Hookers for $159.00 for your 67-69 Smallblock Camaro and they were alot easier to change than an 02 SS Camaro. I know they make quality header bolts Stage8 etc etc but what have you discovered with these LS1 Camaros??
Thanks
01-20-2009, 06:59 PM #2
- Jun 2008
- Decatur Al
NBM- 99 Z28
I put a set of pacesetter ceramic coated LTs on my car last summer. I used the bolts that came with the headers. I've checked mine three times and they have not backed out any yet. I used a set of percys dead soft aluminum gaskets and have had no problems with leaks. I think most people use stock replacement gaskets though.
01-20-2009, 07:01 PM #3
Percys
Them percys cost you $35-$50.00??? I know they are good.
01-20-2009, 07:07 PM #4
- Jun 2008
- Decatur Al
NBM- 99 Z28
I wanna say they were like 60 shipped I was going to get their locking header bolts also but they were out of stock and i couldn't wait.
01-20-2009, 07:43 PM #5
locker header bolts are good way to go. just gotta check them header bolts every now 'n then.
01-21-2009, 08:27 PM #6
I always go back and re-torque the bolts after a heat cycle or two when putting them on but after that I haven't had any issues with them. I bought stage 8 bolts but to be honest with you putting the locks on there was a bigger pain in the ass than just retorquing them. Not to mention if you pull the headers off for something now you got those locks to drop all down the sides of the motor when you're removing them.
Not sure if you've seen the stock gaskets but if you do you'll understand why people either replace with stock or re-use their old ones. Gaskets have come a long ways. Stock gaskets are 2 ply metal gaskets.
Question: header bolts
By jodmari in forum General HelpReplies: 1Last Post: 10-21-2014, 06:15 PM -
Header bolts
By Bender10 in forum External EngineReplies: 4Last Post: 01-06-2008, 06:23 PM -
Header Leaks?!
By HottNixLS1 in forum External EngineReplies: 13Last Post: 08-14-2006, 03:05 PM -
Header bolts
By 87Iroc-Z in forum External EngineReplies: 4Last Post: 05-07-2006, 04:22 PM -
header bolts?!?!?!
By SLP00blueSS in forum External EngineReplies: 4Last Post: 03-19-2006, 05:26 PM
