Results 1 to 10 of 10
01-15-2009, 07:43 AM #1
- May 2007
- Hedgesville, WV
Torrid Red- 2004 Pontiac GTO
Anyone else have a recurring ABS fault?
Well its been a while since I lasted posted here, but it's winter and the GOAT is hibernating until spring.
Here's the question: I have had a recurring ABS fault causing the ABS light to come off and on has anyone else had this issue?
I have had it in the shop about 8 times for this problem and everytime it was fixed the light came back on several days after I got it back from the shop. All repairs were made while it was under factory warranty, but that has expired. It's minor, but irratating.
Another question would be, since it was repaired under warranty would it still be covered since the problem still persists or am I gonna have to shell out some bucks to get it fixed?
By the way my GOAT is a 2004 M6.
Thanks in advance for any and all thoughts on this issue.
01-15-2009, 08:33 AM #2
- Jan 2009
- North Jersey
Check the rear speed sensors on the diff(small black thingys on either side of the diff cover). One or both could be out of sync or too close/far away from the exciter(gear looking thingys) rings on either side of the diff. Could need to be spaced closer or shimmed further apart.
01-15-2009, 02:46 PM #3
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
questions, did you put diffrent tires on for winter? is something like snow getting packed in between sensors? do the reluctor wheels look evenly spaced away from the sensors? was it the front sensors on the front wheels checked they will do the same thing..need more info..
01-16-2009, 03:00 AM #4
- Retired Outlaw Sum Bitch
Take a business card and make sure your rear sensors are no more than the thickness of that business card from the exciter (gear)....
01-16-2009, 03:46 AM #5
- May 2007
- Hedgesville, WV
Thanks for the posts guys!!!
No snow tires on my beast, she's garaged until spring time.
I will check on the speed sensors on the diff. and in the front.
Sarge, thanks for the business card tip that should help alot.
I'll post when I check it all out this weekend!
One last thing.... GO STEELERS!!!!!!!!!! I was raised in da 'Burgh so I bleed black & gold!!!! Here we go Steelers!! Here we Go!!!!!
01-16-2009, 03:52 AM #6
- Mar 2008
01-16-2009, 05:22 AM #7
- Jan 2006
- Chesapeake, VA
Barbados Blue- 2004 GTO
The spec is 1MM. Also check your connections. If you have a low battery (I know you didn't in this case) one of the first alarms you will get is ABS for some reason. So the connections are mounted in the overhead above the diff housing. Pull them down and apart. The just pull straight apart. Clean them up and put some dielectric grease in there.
01-21-2009, 03:11 AM #8
- May 2007
- Hedgesville, WV
Thanks for all the input guys!!! I finally got around to checking everything out over the weekend and it turns out my battery is the culprit. It was a little low on its charge, so I charged her up and everything is gravy!!!
01-21-2009, 03:14 AM #9
Good....yeah low battery makes these cars do weird things. My battery was low and voted for Obama. WTF was that all about?
01-22-2009, 04:17 AM #10
- Mar 2008
I dont care who you are thats Fckn funny,,i had a similair experience car would start but not run,could be driving along and it would just die,battery was junk,put another one in cleared the codes with MY HP tuners and off i went.
It's the Tea Party's fault....
By Frosty in forum Political / Debate ForumReplies: 4Last Post: 08-07-2011, 09:09 PM -
'05 airbag fault???
By Fester801 in forum GTOReplies: 2Last Post: 03-04-2011, 08:37 PM -
Was that my fault?
By FSANE in forum Almost Anything GoesReplies: 36Last Post: 06-06-2010, 04:51 PM -
Air Bag Fault
By Mich's04 in forum GTOReplies: 6Last Post: 08-05-2008, 07:27 AM -
It is Bush's Fault!
By Sarge in forum Political / Debate ForumReplies: 10Last Post: 02-17-2006, 09:29 AM
