Results 1 to 15 of 15
    Junior Member maxgee's Avatar
    Feb 2006
    S Florida
    35th SS LE
    'Fuel pump...you running one or two for FI?
    I've been running one Walbro for my set up front mount 8psi.
    Was told I should run 2 as there's a fuel pressure drop with just one.
    Anyone with this experience? and what are you running 1 or 2?
    35th Ann SS LE
    TECH Fanatic AFASTYZFR1's Avatar
    USA
    Sunset Orange
    2001 Procharged Camaro SS
    I am running two pumps......second one is on hobbs switch
    01 SOM SS D-1SC Tuned by Steve: TunedByFrost.com
    FQuick Garage 764 rwhp / 645 tq
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    same here i am running a dual intake setup with second pump on hobbs switch.
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    I'm running one external aeromotive pump.....
    Blown and Stroked TNTramair's Avatar
    philly
    2000 trans am ws.6
    +1 on the 2 intank Racetronix pumps with a hobbs switch. on 1 pump you may experiance some pressure drop at higher rpms.
    2000 WS.6 Trans am M6
    402 W/APS Twin turbos for support...
    1999 Firebird Formula Hardtop M6
    www.cardomain.com/id/twinturboramair
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    I run two and regularly set up these systems as such.
    We sell a Hobbs switch without the exposed terminals... a nice weather tight connector. Here is our list of Hobbs switches and accessories:
    http://www.lsxtune.com/shop/index.php/cPath/129_174
    doylestown, Pa
    SILVER
    2004 CTS-V
    What does the hobbs switch do?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Racetronix Twin In-Tank Pumps
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It lets you run a single pump until you go into boost and then it switches on the second pump.
    doylestown, Pa
    SILVER
    2004 CTS-V
    So at what point is 2 pumps necessary? I am running 8# at 480rwhp. I do not notice my pump flinch once.
    Member Tman's Avatar
    Woodstock, GA
    2000 WS6
    Two pumps...stock and a Racetronics outside booster
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    Quote Originally Posted by maxgee View Post
    I have the nasty twin in tank pumps ,i am running 13-15 psi would not go any higher on one pump then 6-8 psi not a good thing.
    Laugh while you can... mistermike's Avatar
    Cleveland
    2004 GTO
    I'm running a single Mallory pump
    It's 160 GPH and driven by two Hobbs switches and a PWM controller, giving 3 speeds of operation "idle/light cruise," "power enrichment," and "break something."
    I chose this type because:
    1. It's external. I dislike in-tank pumps.
    2. It's a gearotor type, quieter and more reliable than vane or turbine pumps. Completely rebuildable.
    3. It does not use the fuel for cooling itself, saving your octane for the motor to use.
    World's only twin screw Pontiac GTO
    Blown H/C 408 and other stuff, billet tires, stage 3 keyboard
    2008 HHR SS tweaked by GMPP
    Feb 2006
    S Florida
    35th SS LE
    i got my second pump and found a thread on another forum how to mount it. curious, to know how to run the hobbs? i saw the switches on your site.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It just turns on the relay to power (or ground) the second pump. You hook up a vacuum line to the other side to let it 'see' boost.
  1. Fuel pump fuel guage issues on my '02 B4C
    By ANDYZ28 in forum Camaro / SS
    Last Post: 12-29-2014, 10:30 AM
  2. Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
    Last Post: 03-15-2011, 09:20 PM
  3. running new lines for fuel pump
    By JAX04 in forum GTO
    Last Post: 03-12-2011, 04:30 AM
  4. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  5. Replies: 3
    Last Post: 10-02-2006, 06:23 PM
