    GET SOME claytonr's Avatar
    San Antonio, Texas
    Pewter Metallic
    2002 Pontiac Trans AM
    Got a squeek...help me locate it
    i know this is gunna be like a needle in a hay stack especially for you guys..but i can help narrow it down..it is a light metal on metal squeek on the front of my car..pretty sure its in the engine bay but you can hear it very well listening by the front driver side tire... it does it moving and sitting still..i thought it could be a pully maybe but its more to the side and back of the motor?? anyone every had anytrouble like this?? mabye fuel or brake lines rubbing??
    marlborough, ct
    rally red
    2000 Chevrolet Camaro SS
    I had something similar to this about 5 months ago when I did all the suspension work on my SS. Turns out the one part which I never upgraded which was my shocks was making an annoying squeek noise in the back. They got replaced after that so maybe that will help you. Your car have alot of miles on it? Try and think of when you can remember first hearing the noise and if you made any modifications around that time.
    San Antonio, Texas
    Pewter Metallic
    hell ya it has 115k i havent done any recent mods but when i bought it it had different shocks and a lowering kit..it sounds like thats where it could be location wise..i got under it the other day but it was on jack stands so i didnt want to start it.??
    Member Eric1987's Avatar
    Long Beach, California
    1999 Z28 Convert
    115k isnt a lot of miles...
    marlborough, ct
    rally red
    Mines only got 39,000 miles and is a 2000, when you do mods to your suspension like lowering it it changes the position of the shock and like mine started to leak fluids causing it to squeek.
    San Antonio, Texas
    Pewter Metallic
    thats prolly what it is then..i am pretty mechanically inclined but i cannot find it without a lift..ill get it looked at and prolly get the shocks replaced!
    marlborough, ct
    rally red
    Hey clayton just following up if you fixed your problem or not. Curious if you got that fixed.
    San Antonio, Texas
    Pewter Metallic
    nope i have been veryyyy busy with school and work
    UberTapping Friction Pimp Anthracis's Avatar
    Omar's Tittie Taverna & Grill, Deh Rawod
    18D Cock Diesel
    1999 Z28; 98 SS #2043 RIP
    My car was squeaking too when I got it. The shocks were leaking. When I put in the lowering springs, I changed the shocks and it went away.
    "I am the executioner. When a crime is committed and the exalted state does not take vengeance nor move to punish, then comes time for the executioner to declare himself. I have waited long enough. The criminals are hereby sentenced to death. By fire. By earth. By water."
    San Antonio, Texas
    Pewter Metallic
    ya mine is lowered so that could possibly be it..cant hurt putting new shocks anyways..thanks
    Dec 2008
    johnson city
    2002 chevy camaro ss slp
    On the problem with a squeak up front check the hood latches there is when hood is closed a slight hook that goes in to the top part of the hood latch ,look at the hook part ,use cresent wrench to move it towards motor slightly or towards your fender try to see any rubbing of paint off hood latch i found my squeak after about a year or so.
    San Antonio, Texas
    Pewter Metallic
    sounds good
  1. Locate IAT Sensor???
    By samsz28 in forum Computer & Tuning
    Last Post: 11-07-2014, 11:28 AM
  2. Seattle! I need help trying to locate my old car.
    By 1999nbmZ in forum Western Members
    Last Post: 05-01-2013, 05:54 AM
  3. Need to locate a needle named Zamora in a Haystack
    By Mean Green Z28 in forum Almost Anything Goes
    Last Post: 12-18-2008, 02:21 PM
  4. looking to locate
    By jprice in forum Great Lakes Members
    Last Post: 09-11-2008, 08:22 PM
  5. Locate A Tuner
    By bigmac776 in forum General Help
    Last Post: 07-28-2007, 12:40 PM
