01-09-2009, 02:18 PM #1Member
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
What pushrods with crane rockers?
I am doing a cam swapp and i got a set of Crane gold race variable ratio rockers, the 1.7s. the kit that i got had 7.25 length pushrods in the with them. the springs that i got had pushrods that are 7.4. i know stock length pushrods are 7.4 but do i need to run the 7.25 with the crane rockers? i was wondering why they came with the shorter pushrods and if i need them.
01-09-2009, 07:23 PM #2Junior Member
- Aug 2007
- Carthage,tx
Navy Metallic Blue- 2000 Camaro Z-28
I believe you can run the standard length pushrods as long as the base circle of the cam hasnt been changed. In my opinion and from what ive learned the stock length pushrods should work just fine. If youve changed cams id recommend contacting who the cam is made by and see what they recommend.
01-10-2009, 11:46 AM #3Member
- Jun 2007
- Dalzell, Illinois
i changed the cam but i thought you just run normal length pushrods unless you mill the heads. since the rockers i got have shorter pushrods and they are for LS1s i dont know what rods to use. do i need the shorter pushrods with the Crane rockers?
01-10-2009, 01:59 PM #4Junior Member
- Aug 2007
- Carthage,tx
True. running the stock length pushrods should be just fine as long as the the crane rockers are the same ratio as the stock units. I dont understand why they would send you a different length. If you have been running the cam with the stock rockers and standard length pushrods,and it ran just fine id see no reason to change the pushrod length. If you do put shorter pushrods in there it will affect the camshafts lift profiles .
01-10-2009, 02:05 PM #5Junior Member
- Aug 2007
- Carthage,tx
Id really recommend contacting crane and ask why they put the shorter ones in the kit. The ratio of the crane rockers could be a little more than the stockers, that might would be the reason for the the shorter pushrods. Contacting them would be your best bet.
01-13-2009, 01:38 PM #6Member
- Jun 2007
- Dalzell, Illinois
for future info for people searching. i called Crane tech line and they told me to use the shorter pushrods that came with the kit.
01-14-2009, 11:10 AM #7Junior Member
- Aug 2007
- Carthage,tx
Good deal man , maybe the shorter ones might be a little quiter than the stockers. Did they say why ?
01-14-2009, 11:23 AM #8Member
- Jun 2007
- Dalzell, Illinois
they said they put the rockers at a better postion.
01-14-2009, 11:24 AM #9
yes you must use the shorter 7.250 pushrods. i've had the 1.8 rockers on both cars.
Help: problem with crane rockers!
By stephen02ws6 in forum Internal EngineReplies: 20Last Post: 04-29-2009, 08:58 PM -
Crane Roller Rockers hp???
By CandyRedZ28 in forum Internal EngineReplies: 3Last Post: 02-21-2007, 08:04 PM -
Crane roller rockers
By CandyRedZ28 in forum Internal EngineReplies: 7Last Post: 09-23-2006, 03:17 PM -
Crane 1.89 rockers, pushrods, and cam F/S
By eviLS6 in forum Parts For Sale / TradeReplies: 5Last Post: 02-19-2006, 08:37 PM -
Crane roller rockers?
By pewter02z in forum Internal EngineReplies: 6Last Post: 02-05-2006, 06:54 AM
