Results 1 to 15 of 15
Thread: Underhood Crickets
01-08-2009, 03:49 AM #1
Underhood Crickets
Anybody else having trouble with belts sounding like a box of crickets under the hood? I guess its because all of the rain we've had had here in ATL has created ALOT of moisture in the air? I just put a new tensioner on it and a new belt thinking one of the two would fix it but NO LUCK!
Any suggestion that will last? I was going to put some belt dressing on it from local autoparts store but it says right on container in big letters NOT FOR USE ON SERPENTINE BELTS! I was thinking maybe white lithium grease?
Any advice would be appreciated.
Chekm8
01-08-2009, 04:00 AM #2Member
- Sep 2008
- kansas city mo
black- 2000 camaro ss
mine was doing the same thing. it turned out to be the idler pulley under the ac compressor. $38 from gm parts direct. take your belt off and spin and wiggle all the pulleys by hand .
01-09-2009, 03:17 PM #311 years of bangin gears
- Jan 2009
- North Jersey
This is good to know as my car does the same thing between shifts. I had a feeling it was the pulley. I guess all LSx motors do this? With high mileage at least?
01-13-2009, 09:26 AM #4Member
- Sep 2008
- kansas city mo
mine only has 44k on it.
01-13-2009, 12:47 PM #5Senior Member
- Feb 2006
- Orange County, NY
Don't put any dressing or grease on the belt otherwise it will be ruined.
01-13-2009, 01:19 PM #6
I changed my upper tensioner and it turned out to be the lower one that was making noise....lol.
Changed that one and the noise ceased.
01-14-2009, 07:28 AM #7Junior Member
- Sep 2006
- Georgia
red black- 98Z28
Another vote for the AC idler pulley. Mine sounds just like you describe.
01-14-2009, 01:19 PM #8
Yeah 9 times out of 10 it's the AC tensioner not the upper tensioner.... I have the same problem...
2000 Camaro SS, M6, Edelbrock LT's, Eibach Pro-Kit, Edelbrock Adjustable Coil-Overs
1986 Camaro Iroc LS1 Swap In Progress
Blue Magic...
Like Pepsi It's A Brand Name...
01-14-2009, 01:29 PM #9
Yeah, its a pain in the dick to get from over the top too.
01-14-2009, 07:51 PM #10
Mine makes the same damn noise. Changed the main belt drive tensioner pully and that didn't fix it, although the bearing was considerably worn.
Listening closer, it sounds like its coming from down low by the A/C drive, I'll have to pull the belt and see which one is squeaking.
01-15-2009, 02:35 PM #11
01-15-2009, 03:08 PM #12BLKHWK
- Oct 2008
- New Brunswick Canada
Black- BLK TA modded 12.2@113mph
I just did the same thing I changed the top one and the noise is still there I was going to try the belt next but I'll check the bottom ac first
01-15-2009, 05:40 PM #13
01-16-2009, 07:33 PM #14
01-19-2009, 03:03 PM #15I have a need for speed!
- Dec 2006
- Standish,Maine
Artic White- 00 SS Vert.
It probably is the A/C belt tensioner. I've replaced a few at work.
JIGGER RACIN'
2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
http://www.cardomain.com/ride/2939958
http://i158.photobucket.com/albums/t...amarolaeft.jpg
Crispy Exonerated from "Bridge-Gate"... LSM Crickets...
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 12-08-2014, 07:02 PM -
Question: Are these 2 computers underhood OBD 11 ?
By denegrader in forum Camaro / SSReplies: 4Last Post: 05-30-2011, 01:04 PM -
Question: underhood
By pewter Z28 in forum Camaro / SSReplies: 11Last Post: 04-08-2011, 05:14 PM -
Question: mirror for underhood
By saucycrossover1 in forum Appearance SectionReplies: 3Last Post: 08-24-2010, 02:33 PM
