Results 1 to 18 of 18
    Member onetroubledguy's Avatar
    Dallas, TX
    1999 Trans Am WS6
    How to install white A4 shifter overlay? (Solved)
    Edit: Solved. See below.
    I have installed the overlays for everything else, but I'm not sure about the shifter. The panel can be removed, but the overlay comes with the panel. I didn't completely remove the panel because I would have to take off the shifter, which I didn't have time to do tonight. I'm guessing I will have access to the shift housing once I have the panel completely disconnected and removed.
    Is that right or is there more involved?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Two 7mm bolts take off the console top and 4 7mm bolts remove it.
    Should be easy as hell to do.
    Dallas, TX
    1999 Trans Am WS6
    Yeah, I removed the console top but you can't get access to the gauge since it is included inside of it.
    Beaver Dam KY
    79 T/A -91 Firebird
    Sorry I read wrong
    Ive had mine out a few times trying to kill the rattle, I honestly dont remember. Might have to lay it overtop of it
    BUMP
    Dallas, TX
    1999 Trans Am WS6
    Here's a picture of the shifter on the left: http://i40.tinypic.com/e5igxt.jpg. I don't think you can just stick it over the gauge because as you can see it's extended on the ends.
    Auto Painter RyanJM's Avatar
    Houston, TX
    I put one on my car took 15 min or so.
    1st small flat head to pop the clip out of the shifter so youcan get it off.(easy)
    2nd open the armrest and take out the 2 bolts under the change holder in front. then just pop the console off and slide it back till the front clears the dask.(put the car in d,3,2, or 1 makes it easier to slide.
    3rd flip it upside down unplug the light andundo the 4 bolts. ( you can the pop it out, need to use a little pressure.)
    Last clean and install overlay. then just put it back toghter.
    Shouldn't take more that 15 to 20 min, depends how organized your tool set it. Took me more time to find the socket than install the overlay.
    Dallas, TX
    1999 Trans Am WS6
    Quote Originally Posted by RyanJM View Post
    I follow you for everything but the first. Where is the clip on the shifter that you pop? I thought it was a bunch of small screws to undo it. I guess that's my only issue, removing the shifter lol.
    Beaver Dam KY
    79 T/A -91 Firebird
    The shifter comes out with a simple screwdriver. It has a staple in the front of it.
    Stang Killer TransAmFanatic's Avatar
    Feb 2008
    Harvey, La
    1999 Trans Am
    whats the website where i can get those over lays at?
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    Dallas, TX
    1999 Trans Am WS6
    Alright. The shifter was extremely easy like you guys said. I just used a flathead to remove the clip (no screws at all). It's on the stick-side facing the dash for anyone wondering, which is why I couldn't see it last night. I installed the overlay today. Thanks guys as always.
    St. Louis MO.
    00 Trans Am/Auto
    No problem. glad it all worked out. I like having the white overlay.
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    Quote Originally Posted by onetroubledguy View Post
    (Everything, Installed.)
    St. Louis MO.
    00 Trans Am/Auto
    LOL.
    Dallas, TX
    1999 Trans Am WS6
    Quote Originally Posted by PontiacFan View Post
    Haha. I will post some tonight, geeze.
    Dallas, TX
    1999 Trans Am WS6
    Well, I got everything installed and I realized today that after I installed the speed/tach overlay, the speedometer needle no longer works. It resets with the tach but is stuck at zero no matter what speed I drive. Everything else works fine. Any ideas?
    St. Louis MO.
    00 Trans Am/Auto
    OMG. Did you move it some how? Did you get the 'no needle remove' type? or did you get the ones where you have to remove the needle?
    Think about how you either put it on and how you bumped it or remember how you removed the needle if that were the case.
    Dallas, TX
    1999 Trans Am WS6
    It was needle-less. You just slip them over the needles. What should I do? I think I will make another post since this is not really on topic for this one.
  1. White Shifter knobs???
    By 02 Camaro SS SLP in forum Camaro / SS
    Last Post: 05-25-2010, 06:30 PM
  2. Question: white face gauge overlay
    By 02fbody35th in forum Camaro / SS
    Last Post: 03-23-2010, 05:32 PM
  3. Macewen Motorsports White Gauge Overlay
    By SicWs6 in forum Firebird / WS6
    Last Post: 05-13-2009, 12:55 PM
  4. pics after Z28 badge vinyl overlay install
    By fullthrtle in forum Member's Rides
    Last Post: 02-09-2009, 05:51 PM
  5. Camaro SS White gauge overlay
    By doberman 152 in forum General Help
    Last Post: 10-25-2008, 03:31 PM
