Results 1 to 10 of 10
Thread: 1LE Camaro's/Firebird's Unite
01-02-2009, 06:11 PM #1TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
Anyone else out there 1LE? I wanna see some pics and stats.
01-05-2009, 06:09 PM #2TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
i guess im all alone!
01-10-2009, 04:01 PM #3Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I thought all SS/WS6 cars were 1LEs.
01-10-2009, 06:13 PM #4Impounded
- Oct 2007
- Beaver Dam KY
01-11-2009, 12:10 AM #5
01-11-2009, 08:47 AM #6Impounded
- Oct 2007
- Beaver Dam KY
Hmm I did some digging...we are both right . lol
"The intro of the 4th gen F-bodies brought some change to the 1LE package. No longer was the option hidden beneath any other option codes. You could now simply order the 1LE package by itself. When doing so, you received the same aluminum driveshaft that was installed in the third-gen cars, much stiffer deCarbon shocks, and the same front and rear springs as the standard V8 F-body. Some of the parts that were no longer included with the 1LE package were the larger front disc brakes and the special gast tank. The new F-bodies now had standard front brakes that measured 11 inches. Unfortunately, you still had to delete A/C in order to get a 1LE, so sales remained failry low
At the end of 94, some minor changes were made on the 1LE. No longer was the larger 21mm rear sway bar necessary, because all 1LE cars now received increased-rate springs all around. In 95, only one change was made. They received the same radiator baffling used on A/C equipped cars to increase cooling. The changes made on the race ready option during the 96 model run were the most significant. For one thing, A/C now became standard on all cars, including the 1LE. Koni double adjustable shocks now also a pat of the 1LE package were a great upgrade. Also, in order to order a 1LE, you had to buy the WS6 option.
The only options required to order a 96-97 1LE car is the basic option group (1SA) and the WS6 performance package. You must also specify 6-speed only. Your remaining choices are limited to rear window defogger and/or a front licence plate bracket. "
-Source: High Performance Pontiac. -
The Fourth Generation Cars
The fourth generation Camaro was introduced in 1993 and was instantly popular. What the 1LE racers wanted to know though, was how this change would affect the cars they would now be competing in. Chevrolet did offer a 1LE options on the fourth generation Camaros in 1993, but few were actually ordered. Some new updates were then included to make the 1LE option more appealing to the buying public. The addition of a Borg-Warner T-56 six-speed manual transmission made a great impact as the fifth and sixth gears added to performance and also to top end. T-56 transmission ratios: first: 2.66, second: 1.78, third: 1.3, fourth: 1:1, fifth: 0.74, and sixth: 0.50.
Koni had become almost the exclusive manufacturer of the racing shocks which were usually installed in preparation for competition on all 1996 and later 1LE Camaros after they left the showroom floor. The Koni double-adjustable racing shock was well accepted and successful trackside, but thought to be too high-end for public use.
For the fourth generation, Koni contracted with GM to become the new shock supplier for all 1LE Camaros. The 1993s already came with an upgraded antilock braking system that was lightyears ahead of the third-generation version and if you bought a 1LE-equipped Camaro after 1993 you'd get much more than that for your money. GM began supplying Koni shocks on all four corners and including a little-known, unmarked instruction sheet in the glove box of each car explaining how to tune and adjust the shocks for the best handling on any track surface.
Along with the Koni shocks, Chevrolet really went all-out on the suspension upgrades for this model. Chevy also offered higher-rate durometer bushings on the front and rear control arms and panhard bar, stiffer coil springs on all four corners, a larger 32mm front sway bar, 21mm rear, and a beefier transmission mount for manual transmission-equipped cars as part of the 1LE package. This 1LE package was now being targeted at performance enthusiasts, not just hard-core racers, and in 1996 all Camaros came standard with air conditioning. Another little known fact is that all fourth generation Camaros came standard with a black painted roof, but the 1LE-equipped cars could be ordered with a roof painted to match the body color. All 1LEs automatically deleted the fog lamps on Z/28s, adding another outside telltale sign to its performance potential (someone at the Koni graphics arts department didn't notice that fog lamps are erroneously present on the Z/28 used in the Koni advertisement).
Sometime around 1995, Chevrolet no longer wanted to sell these cars only to racers and even promoted the 1LE option, now know as the Performance Suspension Package, in its public relations packets which is sent out to media and dealerships nationwide. What began as a hard-cord racing upgrade, meant only to win races at the track, turned into what is now a popular sales incentive for performance enthusiasts looking for just a bit more out of the Camaro. As Chevy points out in its own literature, the 1LE is "engineered specifically for professional racing and is intended for serious performance enthusiasts only."
The 1LE option was discontinued in 1999. GM's reason was the cost of keeping an inventory of parts for such a low production vehicle was not profitable. SLP brought back the 1LE option in 2001 on Camaro SS and Firebird Firehawks ordered with RPO Y2Y options. There are also no longer restrictions on comfort options and the SLP 1LEs are available with what serious performance enthusiasts may call sissy-ish things like air-conditioning, power leather seats, power windows, power locks, cruise control, T-tops, etc.
Since T-tops are standard on the Trans Am and Formula for 2002, all Firehawks will have T-tops, too
(From 1le.net)
Here is what you need to have the "factory correct" 1LE Package.
01-12-2009, 10:12 PM #7TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
wow thats alot of info. thanks but i guess im still all alone here. i give up
01-14-2009, 07:36 AM #8Junior Member
- May 2006
- Michigan
RED- 2002 Camaro SS
I have a 35the with the 1le suspension.
01-15-2009, 03:33 PM #9Awaiting Activation
- Oct 2008
- Pa
Blue- 2000 TA
I have an early production 2000 TA WS6 with 1LE springs
01-23-2015, 06:17 PM #10Junior Member
- Jan 2015
- Shreveport
So I know this thread is old. I just purchased a 99 ss 1le 6speed, found about the 1le's tonight and found out I have 1 of 8 ss 1le's in 1999, and the only white one made, any idea what it is worth?
RED Camaro's unite !
By 9t8z28 in forum Camaro / SSReplies: 420Last Post: 03-12-2013, 05:55 PM -
SILVER Camaro's unite!
By Y2K_CAMARO in forum Camaro / SSReplies: 140Last Post: 09-30-2012, 10:28 AM -
nbm Camaro's unite
By Jays00ss in forum Camaro / SSReplies: 247Last Post: 03-15-2012, 08:35 AM -
S.o.m camaro's unite
By 2002_ss in forum Camaro / SSReplies: 42Last Post: 02-23-2011, 09:56 PM -
NBM Camaro's Unite
By cavpat in forum Camaro / SSReplies: 5Last Post: 09-18-2007, 04:01 PM
