Results 1 to 10 of 10
12-30-2008, 07:08 PM #1Junior Member
- Jun 2007
- san francisco
black- 1999 ss m6
is an ls7 clutch going to work here?
whats up guys!
so my stock clutch is fubar'd i think, and looking at ls7 clutch, my car is basically stock (3.73gears/FTRA/lid/pulley) with a 100 wet shot of nitrous now, but i'd like to put in a clutch that could take full boltons/228cam/150shot
i dont really ever take the car to the track and i rarely spray the nitrous, i also commute in my car and its my only car, so i need something that will last a long time.
the problem is that i dont want to spend a ton of money, i know thats the classic speed question, but my clutch budget is in the 600$ range since with all the other parts i need to install that basically puts me at my 1000$ budget
so that basically leaves me with SPEC clutches (heard too much bad stuff and dont want to shim it) and the ls7 clutch, i like the ls7 clutch because its OEM so its reliable and the fact that it bolts in with no issues (and its cheap! ahah)
so my question is: will the ls7 clutch put up with boltons/228cam/150 shot every now and then? i know thats more then the clutch is rated for but my stock clutch holds 320rwhp+100shot just fine!Last edited by allforspeed; 12-30-2008 at 07:19 PM.
12-30-2008, 07:17 PM #2Junior Member
- Jun 2007
- san francisco
black- 1999 ss m6
FYI the most traction the car will ever have is nitto drag radials and its only a street car, i'm open for suggestions too! also, i really rarely use the nitrous, mostly just use it to scare my buddies and lay the occasional smack down on a turbo honda...hahaha..
12-30-2008, 07:40 PM #3
i have a full bolt on car with the ls7 clutch and it works great. i believe, and someone correct me if im wrong, the ls7 clutch can handle 500hp.
12-30-2008, 08:58 PM #4Junior Member
- Jun 2007
- san francisco
black- 1999 ss m6
thanks man! i know the clutch is rated for 505hp but i'm just hoping/wondering if it would be able to take more than that for short periods of time in a street car that is on relatively non-sticky tires with 3.73 gears too
from what i can gather so far, that basically its only weakness is that it doesn't like to get hot too much so you just need to give it time to cool down. seems like lots of heads/cam cars on here putting down 450+ rwhp use the ls7 clutch without issues which would be 500+ hp at the flywheel.
did you install it? anything special i should know about installing this clutch that is different than any other clutch? did you just use the stock flywheel?
12-31-2008, 12:45 AM #5
12-31-2008, 04:23 AM #6Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
Look into RAM clutches that is what I have in mine right now, and it has been great for me so far. It does chatter a little bit, though that is rather rare now, holds great, and the parts only cost me 450ish.
You should be fine with an LS7 as long as you don't hit it to hard and to often with hard shocks. Just remember the 500 hp rating is flywheel hp and for a much lighter car.
12-31-2008, 10:32 AM #7Junior Member
- Jun 2007
- san francisco
black- 1999 ss m6
bottesini, how much rwhp are you pushing? where did you get your RAM clutch and did you have to shim it? how many miles do you have on it so far?
01-01-2009, 05:26 PM #8Senior Member
- Sep 2007
When I had the stock 10 bolt I was just under 400 RWHP think it was 396. I actually did not install my clutch, but I am fairly certain there was no shim used. I bought and had RPM in Lewisville Texas install my clutch it was a special mix of RAM products, which I don't have the part numbers here, but if you want I can gather them up once I am home. The total cost for parts was right around 450 for the pressure plate and clutch.
As for how many miles I have on the car with the new clutch I think it is around 15K maybe 20K. It is my daily so it sees lots of normal street type situations like traffic and the highway. Still grabs great and now that I have a Moser 9" can not wait to put some stickies on and drop the clutch at 5k RPM.
01-17-2009, 05:52 PM #9
ls7 clutch
Looks like here we have peole running LS7 clutchs!!!! I was bone'n up on it and it has a clutch adjustment on the pressure plate. which can be done on the vett ....... I'm wondering how you can do it in th F body?? Any one look at this? wondering before I buy my clutch.......Thanks
01-18-2009, 06:10 PM #10Junior Member
- May 2006
- Deltona, FL
Silver- 1998 Camaro Z28
Mine holds fine with 458 rwhp on a blown 98 Z28. I have no idea how you would or why you would adjust the LS7 clutch. This will stay till I build a motor and aim for 700+hp, and will go twin disc at that point.....
Mike
1998 Z28 Procharger and stuff
2007 Chevy Avalanche
Is recall work warranty work?
By RealLiveMD in forum Almost Anything GoesReplies: 19Last Post: 04-30-2010, 05:20 PM -
What flywheels will work with LS7 clutch?
By GottaHaveLS1 in forum Manual TransmissionReplies: 2Last Post: 04-16-2009, 07:05 AM -
anyone else work a shitty shift at work
By issues in forum Almost Anything GoesReplies: 37Last Post: 08-18-2008, 01:17 PM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM -
z06 clutch for sale, pressure plate clutch disk and flywheel
By themack56 in forum Parts For Sale / TradeReplies: 2Last Post: 07-06-2006, 07:15 PM
