Results 1 to 11 of 11
    doylestown, Pa
    SILVER
    2004 CTS-V
    Procharged LS1(catch can filling up with water)?
    I am not sure if I am posting this in the right section, but I figure that my problem has something to do with having a supercharger.
    I have been getting alot of water(moisture?) in my catch can. In the summer months the catch can would be half filled with milky oil every oil change at 2K miles. Obviously it was mostly oil with a little bit of water. I know that it was only a little bit of water or else I would have seen the oil and water seperate. Now, it the winter time, the catch can is 1/3 full of strictly water? I have a vented breather on the passenger valve cover and thats it. I thought that the air filter could be sucking up water but it is not exposed enough for the amount of water I am dumping out of the catch can.
    I did a compression test on the cylinder and I tested the coolant syatem and all tested good. Even the oil on the dipstick and drained oil looks fine and the antifreeze is green.
    All of the water in the catch can is basically clear.
    What could be the cause of this?
    Aug 2001
    San Diego, CA
    383 w/Meth & ProCharger
    2001 Camaro Z28
    Normally the milky goop that's collected is an indicator that you heads are lifting under boost. I know you're not making a ton of boost but have you retightened the head bolts? You can put some aluminum radiator seal in your cooling system. I had similar thing going on and that stopped the milky goop collecting in the catch can. Not sure exactly what's going on with the pure water. I'm guessing some kind of heat related moisture residue and not any coolant.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Well, the milky residue will naturally build up. You can see the same thing when you take off a naturally aspirated engines oil fill cap. You generally see some moisture. I drive the car 40 miles everyday so it definitly has enough heat to evaporate the moisture. I assume that the Procharger does build moisture as does the air compressor in my garage which is evident by the air to water seperater.
    The heads have been retorqued and I can't see them lifting and causing excessive moisture.
    Member Sweet Chops's Avatar
    Manitowoc, WI
    Hugger Orange
    1999 Camaro Z28
    I get the same Liquid and I am NA. Just not as much as what you are talking about.
    Ryan
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    It's condensation and completely normal.
    here
    2001
    +1
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Winter months will produce a ton of moisture in the crankcase, which would normally just be sucked into the engine via the PCV, burned, and exhaled as white smoke when the car is first started.
    Since you have a catch can, you're seeing all the moisture and crap thats making it out of the crankcase but not being burned in the engine.
    Sounds like what you're seeing is pretty normal to me. If it was a head gasket issue it wouldn't be just water, it would be milky crap from the antifreeze mixing with the oil.
    Member JattGunMan's Avatar
    cali
    2000 ss
    I read somewhere that the "goop" happens to car with that came equipped with the steering cooler..It because somehow the steering cooler leaks causes steering fluid to mix with radiator fluid...I have a SS and the radiator dip stick is a lil milky
    Member devil6rr's Avatar
    NJ
    SOM / NBM
    2002 Pro Z28/2001 TurboTA
    +1 on that my radiatior dip stick is also milky goop but the fluid is clean
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by JattGunMan View Post
    I do not have the PS cooler.
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    Man,this is all normal,why do you think people put oil catch cans on NA cars ever pull the air intake off and look into your stock throttle body, on any ls motor Na or not? got oil baby! yep they all do it,the water is a natural thing as well how far are you driving the car,the H2o is what happens when the motor is running all that moisture has to go someplace until motor is hot enough to burn it off.the can is doing its job has nothing to do with heads lifting under boost.if that were the cause youd have way bigger problems,head gaskets would let you know really bad things,that plastic tank radiator would say see ya.
  1. Filling Fenders
    By Ed Blown Vert in forum General Help
    Last Post: 07-27-2012, 09:40 AM
  2. Filling up the wheel well
    By Jorgens in forum Wheels and Tires
    Last Post: 08-16-2011, 06:03 PM
  3. Filling Tranny
    By tims02 in forum Corvette
    Last Post: 06-30-2008, 12:45 PM
  4. Question: filling radiator with straight water(flush)
    By Acceleration Junky in forum General Help
    Last Post: 04-23-2008, 07:52 AM
  5. Water In catch Can
    By SStriker in forum General Help
    Last Post: 07-07-2007, 05:27 PM
