Results 1 to 11 of 11
    revalved bilisteins?
    are "revalved bilisteins" something you buy, or a mod you do like a "drill mod" to the slave cylinder? If it is a mod, how does one go about doing this?
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    You can buy them from SLP, that's where I got mine. It's a mod: you buy the shocks, take out your old ones then install the new Bilsteins. Bilsteins are a gas pressurized monotube shock - there's nothing the purchaser can do to modify them, or as far as I know, any other shock. Any adjustable shock has that capability already designed and built in when you buy it, such as some Koni's and QA1's. I've had problems with Koni's in other cars leaking shock oil from the fiber sealing ring that they use on the piston rod; never had any problems with Bilsteins.
    Ohio
    97 Formula
    Talk to this guy, his name is Sam Strano. He's a suspension specialists and sells revalved shocks made specifically for your application. strano@stranoparts.com
    Buffalo, NY
    1999 Trans Am WS6
    I have talked to Sam Strano about this very same issue. Best advise is to listen to Warbird & contact Sam. He knows his suspension stuff and he's very personable.
    thanks guys, so SLP Bilistiens are the same as "Revalved Bilistiens" ?
    c'mon answer my last question....PLZ!!!
    and that sam guy won't answer my emails?
    Senior Member Carlos01SS's Avatar
    Aug 2003
    Cypress, CA.
    Quote Originally Posted by dipherentdesign
    Yes and no...
    SLP's revalved Bilsteins supposedly have been revalved to match the SLP springs that came with the optionsl SLP Level 1 suspension package from the dealer...This means that the Bilstein's sold by SLP only match the stiffness of the SLP springs, does that make sense???
    Sam Strano can revalve brand-new Bilstein's based on what kind of springs you have-however if you are keeping factory springs then you can get away with Bilstein HD's, they're just fine with the factory springs...
    Now, if you are planning or DO HAVE aftermarket springs, then depending on what springs you have Sam Strano will revalve the Bilstein's to match the stiffness of the springs that you are using, your car will respond TONS better than right now.
    The Black 2001 SS #5697
    T-tops, 6-spd/B&M ripper, ARH LT's/GMMG/CME, Volant, Koni DA's & GC coilovers, Strano frt & rear sways, G2(SFC's w/v-braces, STB, adj PHR), Wilwood 6-piston red calipers frnt brakes w/13" 2-pc rotors, RKSport(clear front & rear corners, c-f grill), chrome Z06 wheels
    Aug 2003
    Cypress, CA.
    call him...
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    Quote Originally Posted by Carlos01SS
    Yes and no...
    Actually, yes it does make sense... since spring rates vary and the SLP springs could be progressive rate, but at the very least a different and probably higher (stiffer) spring rate than what comes stock the best thing you can do is to match the valving characteristics to the springs. Now, whether these Bilsteins are suitable for dipherentdesign's springs I don't know, but they work fine with my stock springs.
    Buffalo, NY
    1999 Trans Am WS6
    I Emailed Arlyn a couple questions about shocks & got a response within an hour. He said that Sam wanted to speak w/ me about my individual setup & he called me that day. I spoke to him for about 30 min. I'm not sure why your having trouble getting a hold of him, he might be really busy or something to that effect. Maybe call the Tech line.
    Here's the contact info just in case you don't have it:
    www.stranoparts.com
    Email: arlyn@stranoparts.com
    Order line: 800/729-1831
    Tech line: 814/849-3417
    Fax: 814/849-6305
    P.S. Good info by the way Carlos!
    Pro 5.0 shifter, CAGS, Borla Exhaust, Direct-Flo Lid, K&N Air Filter, Fast Toys Ram Air Kit, BMR STB, BMR Adjustable PHB, BMR Boxed & Welded SFCs, Metco Boxed LCAs w/ Relocation brackets, Metco Driveshaft safety loop, Koni SA Shocks, Eibach Pro-Kit.
    i got to talk to sam and started a new thread regarding his Koni and stock spring idea...http://www.ls1.com/forums/showthread.php?t=10793
  1. Question: KYB AGX Shocks or Strano's Revalved Bilsteins???
    By Musclecargt71 in forum Suspension and Handling
    Last Post: 08-14-2009, 11:20 AM
  2. Where to buy SLP revalved Bilsteins
    By Speeddemon24_7 in forum Suspension and Handling
    Last Post: 02-20-2009, 10:10 AM
  3. Bilstein/SLP Bilstein/Revalved Bilstein?
    By CWW17 in forum Suspension and Handling
    Last Post: 10-18-2007, 11:27 AM
  4. revalved bilstein rant
    By third_shift|studios in forum Suspension and Handling
    Last Post: 10-02-2006, 04:44 AM
