Results 1 to 18 of 18
    Bragg NC
    Met. Sunset Orange
    01 SS
    Dewalt 18v 1/2" Impact
    Was looking at one at homedepot was curious if anyone had any experiance with the impact.
    Does it hold its charge a while?
    Have decent power?
    It claims around 300 ft pounds but im kinda iffy on a battery powered impact.
    Any pros and cons?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    What are you planning on using it for mainly? Try to see when the rep is doing a clinic and see if you can test it.
    qwkgto brought his over when we did my brothers headers on his goat. That's a bad ass impact. It's on my "to get" list now.
    texas
    1993 gmc typhoon
    i really like mine. when i go salvage yard hopping it really helps
    Junior Member jc99ls1ss's Avatar
    Louisiana
    Bright Red
    1999 Camaro SS
    I really like mine. it holds a charge good if you have a good battery(not to old) and plenty of power to break lug nuts. There are two different ones out. I have the smaller and my brother has the bigger one. Both 18v and 1/2". Millwakee(spelling????) also has a 28 v and it is bad. But a little big.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Do alot of work around the house, Ie Brakes, exhaust work, suspension, so i need it to be able to break the lug nuts loose, also alot of exhaust work lately and an impact would make things so much easier.
    thanks
    J
    NY
    yellow
    02 Collector Edition TA
    Mine works good, it will pull a 110 ft-lb lug nut off, more than my air impact will do at 110psi.
    Veteran Blackbird WS6's Avatar
    van down by the river
    anything Dewalt makes is always going to be good
    Junior Member 2blk2drs's Avatar
    carlsbad, ca
    blk
    01 T/A
    i really like mine, bought it for bolting augers together, between the 2 bat packs, it goes all day
    ROWDY BURNS jsteele90's Avatar
    camp pendleton
    383/372 CMS tuned
    2000 z28
    just got mine this morning for christmas from the wife. it looks pretty badass cant wait to use it
    Member mitchntx's Avatar
    Tx
    Had one for several years.
    Only complaint is the little ball in the snout sticks sometimes locking the socket on.
    Mine claimed 200-something ft/lbs of torque. That claim is sorta like EPA gas mileage estimates. Probably happened to someone, but your results may vary.
    The gun has worked flawlessly ... 18V XRP batteries last a year, maybe two are $60 each. I also have a 3/8" version.
    I would buy again if needed.
    Slowass SUX!!
    Nov 2008
    Cincinnati
    09 Sierra Denali AWD
    2001 T/A WS6 NBM
    i like the Rigid drills Home Depot has .....have good packages also
    Junior Member 1987BuickGN's Avatar
    Irving Texas
    1987 Buick Grand National
    I have no idea what the cost is on the Dewalt, but I purchased Snap On CT4850HO and really like it. Rated at 620 breakaway torque and 400 torque output. Ive only had it for 3 months but so far so good. I only assume it cost more because it is Snap On, but I think I paid like $450. for it. Not sure if that is comparable or not? Ive had 18v cordless drills that are Dewalts and ALWAYS had good luck with them too!
    Member DirtWad's Avatar
    Nov 2008
    Iowa
    `93 &`72 Camaro Z28
    I love my DeWalt. I mainly use it for lug nuts and changing out gears on my race car every night. I previously had a Milwaukee impact, but this Dewalt had clearly way more power. 240ft/lbs vs 300 I believe. I can use my Dewalt to break loose bolts I normally can't break lose with a breaker bar. I would definatly recommend it.
    Coral Springs, Fl
    Sunset Orange Metalic
    Dewalt
    That little impact gun is one of the most badass battery tools that i've ever used. Buy it and you will not be disappointed.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Quote Originally Posted by Blackbird-WS6 View Post
    I have a lot of Dewalt tools and have not had a problem with any of them.
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    Mine is a snap on had last one for 9 years damn thing is the bomb,used it on everything from heads and cam to taking wheels and tires off,Jegs sells a nice one for $100 and so does Minards,<comes with two batterys mine last for a long time but always nice to have a second just in case,one of the best tools a guy can have,get one youll never regret it.
    Los Angeles, CA
    2001 Pontiac Trans Am
    Definately worth the price
  1. impact wrench
    By Guerrillakilla13 in forum Tools
    Last Post: 04-25-2014, 05:33 PM
  2. My new impact wrench
    By 98TransAmWs-6 in forum Tools
    Last Post: 08-06-2012, 04:36 PM
  3. Impact Guns
    By GTP231 in forum Tools
    Last Post: 04-24-2011, 04:22 PM
  4. dewalt 18v 1/2inch impact wrench
    By camaross1 in forum General Classifieds
    Last Post: 05-09-2010, 07:01 PM
  5. HSW Sudden Impact
    By MavrickCJH in forum Parts Review
    Last Post: 01-11-2007, 12:21 PM
