Results 1 to 16 of 16
    Retired Outlaw Sum Bitch
    Diff Major Rebuild Kit
    Diff Technics and "others" seem to disagree on torque specs etc. for their rebuild kit. Anybody here ever install a rebuild kit and if so what specs did you utilize? I'm going to get a major rebuild kit for the axle seals etc. and am curious as there seems to be debate. It has been my experience most rear end issues are from incorrect installations......
    May get some axles/stubs from this guy......while I'm at it.....
    https://www.gforce1320.com/Products.html
    Member Tide's Avatar
    Southeast
    Nothing special
    Nothing special
    I'll be interested to see what you come up with, though.
    Mine is going up on the rack at the first of the year and getting a new clutch, plus a major "what all have I broken" inspection from crankshaft back.
    Sorta liking these frankly.....
    http://www.easttexasmusclecars.com/hendrix.htm
    Southeast
    Nothing special
    Nothing special
    I'd be interested in seeing what the weight differences on those pieces are versus stock.
    King of Lurkers ne0fiend's Avatar
    Clearwater, Florida, United St
    04M6 GTO
    Yikes...
    On stuff like this, Sarge is absolutley right.
    We get a lot of "This is the right way" and "This is the best way"
    The fact of the matter is (and i think most of you will agree) OEM specs are just that, OEM specs. The OEM Specifacations are set in place as a bench mark for you, the Tech to devise the best MOA (mode of action). There are a few key points to keep in mind here and I'll share what I can, based on what I --KNOW FROM DOING IT MYSELF-- Frankly, and I know you'll agree, Sarge, DIY info is more valuable than all the reading in teh world.
    So, based on my rebuild, here's what I know.
    It's important to note that the parts you and I use will harbor variances in their design as well, so again, I am only offering this information as a stepping stone for your project. No one should use these exact specs, unless ofcourse you're using the exact same parts.
    Utilized parts are as follows:
    Hendrix Engineering
    GTO 2 Piece 300M 1000HP STUB
    Hendrix Engineering
    GTO 2 Piece alum/chromoly 1000hp Drive Shaft
    (note) This was freeze treated prior to install. optional step.
    Mansfield Tech
    GTO Power Rear Drive Axles (Up to 900HP)
    Automotive Engineering UHP
    GTO Diff Housing (Polished Steel)
    GTO Rear Drive Comp Seals and kit.
    The rest is self explanitory.
    The specs were as follows:
    note - The information hereafter is based on four (4) trail and error runs.
    Diff lube capacity (drain and fill with *NEW* parts) @ 3 and a half pints
    Pinion flange rotaional torque @ four (4) inch pounds
    limited slip differential friction modifier --IMPORTANT-- 1.0 OZ (I recommend Ultra Gluide)
    The kit I got didn't come with carrier bolts, so you'll need those if you go with the HE kit(S)
    I hope this helps. Or if you need more numbers/math, let me know.
    I have some pics from the rebuild on my camera if you'd like those too. I'm pretty sure anyway.
    OutfuckingStanding! I see you went with the kids in East Texas also....yeah I like what they have designed...makes sense to me.....I am getting a major rebuild kit and probably the axles from Stephen......I didn't say this.,...but I busted a BMR stub about three years ago and just went back to stockers (OEM)....yeah if you dont mind I would really like to see your pics....pics are always helpful.....
    Quote Originally Posted by Tide View Post
    I'll weigh em for you...I can get down to grams....
    04M6 GTO
    Looks like I don't have the rebuild pics on my camera anymore. I've been using it a lot lately.
    Sorry buddy
    Honestly, though - I seriously doubt, SERIOUSLY doubt you'll have any trouble with the install.
    Like I said before, the specs I posted are based on a trial and error, track test.
    The criteria used was 0-60 feet, 0-100 feet and RPM curve under a cornering load.
    So as long as you're using the same kit (which it looks like you are!) you're golden.
    I should stress, however (and i'm sure you know this) that the wear patterns and amounts are unique to every rear end, and minor alterations in the math will be necessary. Like the amount of lube, the type of seals, etc.
    I have found that the micrometer is like your best friend once you graduate to more serious mods hahaha
    ...SPeaking of Mods, i'm going to post a thread about camshafts here in a minute.
    Have any of you guys done any Cams, DIY? Look for the thread. I appreciate all input!
    Good luck, Sarge! I look forward to some pics of the overhaul!!!
    Southeast
    Nothing special
    Nothing special
    Very cool.
    Reducing unsprung weight = WIN. And it's something that's often overlooked given the benefits. Better braking, better handling (mostly in terms of feel), and better acceleration.
    I am also getting the larger diameter axle for the drivers side.....harmonics you know....
    Southeast
    Nothing special
    Nothing special
    Sarge, don't forget to get the weight measurements!
    I will....East Texas Muscle tells me they have shipped so I am in the waiting period.
    Southeast
    Nothing special
    Nothing special
    Sweet.
    Sep 2008
    Madison, WI
    PMB
    2004 GTO
    try and set your backlash closer as well, if you do gears. big plus i think.
  1. Replies: 8
    Last Post: 11-25-2010, 07:19 PM
  2. Need major help
    By Adam_94_T/A in forum Almost Anything Goes
    Last Post: 12-10-2009, 07:28 PM
  3. rebuild ls1 engine with cam, diff gears, maff tune
    By rikkibobby in forum Internal Engine
    Last Post: 08-23-2009, 07:32 AM
  4. I Need Major Help!!!!!!
    By LT1Redneck in forum LT1
    Last Post: 06-18-2007, 07:11 PM
  5. best diff fluid? good diff cover?
    By ErikElvis in forum Camaro / SS
    Last Post: 03-23-2006, 08:49 PM
