Results 1 to 18 of 18
Thread: moser 9 inch
12-14-2008, 07:38 PM #1
moser 9 inch
Hey guys , been a while since iv'e been on. Had a moser 9" put in the car this year. It is rock solid but damn it makes alot of noise. Is this normal ? A little feedback would help. Around town it's a little noisy but 55 or 60 it get just damn annoying. Is this normal or maybe some adjustments need to be made. 31 spline , 370 gear , detroit true trac posi.
12-15-2008, 04:27 PM #2Awaiting Activation
- Aug 2007
- odessa,texas
69 hugger orange- 98 z28
the only time i notice mine is on big bumps and it bangs the underside of the car but other than that it is quiet
12-16-2008, 06:13 AM #3
What type of noise are you hearing? I presume it's gear whine at 55 - 60 mph?
12-16-2008, 06:15 AM #4
I hear the lockers make a ton of noise
sound slike gear whine though to me
12-16-2008, 08:13 PM #5
Mine is about two years old, w/ 4.10's & a spool... It makes the whining sound too. I think my extreme duty torque arm amplifies the noise into the body of the car...
12-17-2008, 06:00 AM #6
12-17-2008, 07:40 AM #7
12-19-2008, 05:46 PM #82 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
9" with locker here. Barely notice any noise at all out of mine anymore. Locker acts up every now and then But it doesn't really bother me.
12-19-2008, 06:38 PM #9
The main thing is, I never have to work on it !!! LOL !!!
12-19-2008, 06:40 PM #10
01-11-2009, 12:21 AM #11
Sorry guys, it's been a while since i could get back on. Yes to answer questions it is gear whine that I am hearing, and quite a bit. After a 250 mile trip I almost threw myself out of the moving car. Should it be that loud or does it need to be adjusted.? 370 gear. I do also have the body mounted torque arm,lower control arms, pan hard bar and sway bar all with urithane bushings. I know it might transfer more noise but seems a bit rediculous.
01-11-2009, 12:27 AM #12Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
Mine with 4.11 is quieter then the exhaust. In fact only on occasion do I even hear the gears back there and I have to listen very closely for it to hear over all the other noises.
One of the things we did when first installing the rear was put the car on jacks (just the rear) and bring it up to about 4th idle. Then we shut the car off with the clutch in and just let the wheels free spin to hear what was going on. Mine was almost dead silent. Also checked after the first few break in drives to see how hot the casing was. I would guess something is not set right.
01-11-2009, 05:55 AM #13
i say the same. where did you get it from and how put it together?
01-11-2009, 06:09 AM #14
You might want to check the gear oil. Any sign of a slow leak ?
The body mount torque does amplify, but your's might need checked.
01-11-2009, 04:04 PM #15
Thanks guys, I have all my work done so I'll bring it back and have them go through it. Getting the trans done anyway so while they have it I'll have them reset it if they need to. I didn't think it should be that loud. I mean I turn the stereo up half way and you can still hear it whine.
01-12-2009, 12:05 AM #16
ya thats not right they will have to reshim the gear set.
01-12-2009, 08:27 PM #17
They said i might get some noise but this is is just too much. Thanks for the input.
01-15-2009, 02:51 AM #18Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Was this rearend bought or was it put together by the installer? If it was bought, I would get in touch with the seller and see what they can or will do to make it right.Don't want to be opening up a rearend that my be fixed by the seller.Now if someone put it together for you they have it setup wrong.There should be very little noise coming from the rearend.
I just got a moser 9in?
By speedy30 in forum DrivetrainReplies: 3Last Post: 03-31-2012, 05:46 PM -
Moser 9-inch Rearend Swap
By midnitejam in forum DrivetrainReplies: 15Last Post: 05-16-2011, 06:17 AM -
Why Moser?
By Bouvers in forum DrivetrainReplies: 32Last Post: 11-05-2007, 03:27 AM -
3 inch Y-Pipe with 3 inch cutout already welded onto it
By Hurley711 in forum Parts For Sale / TradeReplies: 8Last Post: 10-02-2005, 09:59 AM
