Results 1 to 3 of 3
    Impwnded Smkn_TA's Avatar
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Radio install help asap!
    When you pull the radio out, there are THREE connectors. TWO are stuck together as if they are one. I found the wiring diagram and got those all figured out. Then there is a black connector with a red tab on the back of it. It is small and has like 18 pins, only 6 or so have anything on it. The wires are this. White/brown, white/black, Green, Black, and a BARE wire, no insulation on it what so ever. What the fuck is this connector for and what do the wires do? Installing my radio now and I am stumped. Is it to the amp? What do I do with it! THANKS!!
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Answer found! w00t
    and what is it?
  1. help with radio install
    By etownfbplayer in forum Stereo and Electronics
    Last Post: 09-10-2010, 10:35 PM
  2. Radio INSTALL, HELP ASAP!!
    By Smkn_TA in forum Almost Anything Goes
    Last Post: 12-16-2008, 06:02 AM
  3. Need help with install ASAP!
    By clg82 in forum External Engine
    Last Post: 11-03-2007, 03:24 PM
  4. LS7 Clutch Install Help ASAP!
    By ssgtcarroll in forum Manual Transmission
    Last Post: 10-02-2007, 04:16 AM
  5. Need help ASAP, Spohn LCA/PH rod install...
    By SSwt00SS in forum Suspension and Handling
    Last Post: 04-02-2007, 05:35 AM
