Results 1 to 10 of 10
Thread: Headlight assembly?
12-10-2008, 12:34 PM #1
Headlight assembly?
Need help putting my headlights back on.
12-10-2008, 01:15 PM #2
What do you mean exactly?
12-10-2008, 01:57 PM #3
^yeah,what is the problem.
12-10-2008, 08:56 PM #4
I need help putting the hole assembly back in.
I had to take it out because of a wreck.
12-11-2008, 08:15 PM #5
so your car was wrecked and you are going to install headlamp assy. yourself? i'm just trying to get a little more info so i can be better help.
12-12-2008, 09:39 PM #6
Yeahh
I got to get some more parts to get it fixed but I need to know how to put in the headlights lol
12-12-2008, 09:42 PM #7Impounded
- Oct 2007
- Beaver Dam KY
If you have the parts its really simple. Its a giant bracket with 10mm bolts. Take out the two 10mm pivot bolts on top of the bracket that allows the headlight assembly to pivot. should be 10mm with like a t20 bit on one end.
Pop in the brackets then put back in the headlight assembly and the other bolts.
I dont know what all was taken out because of the wreck.
12-13-2008, 03:24 PM #8
12-15-2008, 03:54 PM #9
the headlamps are held in place by a bracket that has 4 holes for T15? torx screws.one bracket per lamp.and then the big black plastic cover goes on around the lamps and is held in place by 3 phillips head screws.you know about billy graham's camaro/firebird salvage yard in calera right,he'd probably have the hard to find stuff like those torx screws and anyother odds and ends you might need.(205)668-1169.
12-15-2008, 04:59 PM #10
iight thank you
I plan on puttin my headlights on by wed.
Headlight Assembly Help
By 9T8WS6 in forum General HelpReplies: 6Last Post: 12-22-2015, 07:01 PM -
headlight assembly
By evilhaserrors in forum Firebird / WS6Replies: 2Last Post: 01-04-2008, 07:11 PM -
WTB: Headlight Assembly 2000 SS
By etucker in forum Parts Wanted / TradeReplies: 1Last Post: 10-07-2006, 06:04 AM -
*Wanted* headlight assembly for '00 Z28
By GeArBaNgEr56 in forum Parts Wanted / TradeReplies: 0Last Post: 04-02-2006, 07:16 PM
