Results 1 to 20 of 22
    Member cobrakiller99's Avatar
    May 2008
    Michigan
    1999 Trans am Ws6
    My friends mom's T/A
    One of my good friend's mom has a 00 formula ta and just recently one of her headlights stop going down, so basically one headlight is down and one is up. Anybody know how to fix this or know what the problem is?
    Pa
    Blue
    2000 TA
    Have the headlight motor replaced.
    May 2008
    Michigan
    1999 Trans am Ws6
    is that the only solution? nothing you can do about it, how much does those things cost?
    Senior Member SS02's Avatar
    None
    Quote Originally Posted by cobrakiller99 View Post
    I think if U want it work, that might be it?
    I am sure there not cheap!
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    might want to take a look at the gear teeth...they are plastic...if they are bald on one side...move the good side to where the bad side was...since the motor only uses 180.....it is most likely a headlight motor...make sure and tell her to not open or close her lights when the car is in motion.
    Shepherd, Michigan
    98' trans am
    oh and by the way...all t/a's are formulas...but formulas arent t/a's
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    Correct. I only open mine at medium to high speed. When I close them, I make sure I'm at or below 40mph. Fighting the wind to close them only wears down the gears.
    May 2008
    Michigan
    1999 Trans am Ws6
    how can you look at the gear teeth? how do you pull the headlight out? sorry guys i have no clue about headlights.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    check out rockauto.com that where i bought my left headlamp motor back in feb.the post about the gear is correct,but i chose to replace the motor because it was a bitch to get the gear cover off,at least it was on mine.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    If that side makes a grinding sound when you try to close it then your gear is fried. If it makes no sound at all check the connection, unplug it, clean it out with electronics cleaner and then use dielectric grease and plug it back in. If that doesnt work then the motor itself is fried. They are usually 112 bucks from gm. I just changed mine out. I DO NOT open or close my headlights when i am moving.
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    a moto cost me about 70 bucks at autozone and i got a lifetime warranty on it. good luck installing it, i had it put it in by a delaer mechanic while i was getting my brakes done. he said he had to take off the front bumper, its a real bitch.
    Junior Member deepblue's Avatar
    Tennessee
    blue
    2001 WS6 Trans Am
    Un-plug the light pig tail and see if it has corroded. If so clean it and apply some electrical grease on the prongs and see it that helps. Water will spray on the plug when driving in the rain. The grease will help with the corrosion. A
    frind of mine had the replace the pig tail due to this. he has 23K on a 2000 TA southern car and seen very little rain.
    May 2008
    Michigan
    1999 Trans am Ws6
    thanks guys, you've all be a big help, im about to do it when he comes back from school and see what happens. how do you unplug the light? do you have to go in from the hood?
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    if you can hear the motor, the gear is stripped. Take off the black headlight trim, take the arm off the motor (10mm nut) and manually rotate the gear 180degrees (the flats need to spin around 180) by turning the motor and reinstall the arm.
    May 2008
    Michigan
    1999 Trans am Ws6
    Quote Originally Posted by That Guy 2-1 View Post
    thanks
    Beaver Dam KY
    79 T/A -91 Firebird
    The headlight assembly comes out with three easy bolts.
    The motor comes out with 3 easy bolt.
    goodluck and keep us updated.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Quote Originally Posted by 1998 T/A View Post
    i have replaced the headlamp motor and the front bumper does not need to be removed,pretty straightforward replacement.
    Beaver Dam KY
    79 T/A -91 Firebird
    A t20ish torx bit and a 10mm rachet will do all the work.
    Member BLAUPLOW's Avatar
    May 2008
    Tracy, CA
    02 ws6
    thread would probably get alot more views if the title was just "my friends mom"
    SOM WS6 fbird777's Avatar
    Kinston, NC
    Sunset Orange Metallic
    2002 Pontiac Trans Am WS6
    Don't replace the whole motor assembly, just replace the stripped out nylon gear with a brass gear from Brent Franker. Why put the same nylon gear back in your car when it may fail months down the line. Here is a link to the headlight motor rebuild kit:
    http://www.bfranker.badz28.com/headlightfix/index.htm
  1. Friends working for friends.... high bids
    By knightryda01 in forum Almost Anything Goes
    Last Post: 06-15-2014, 07:33 AM
  2. A little help from my friends
    By FIREBIRDKID9687 in forum General Help
    Last Post: 10-12-2008, 12:28 PM
  3. Friends
    By superchargedblackgto in forum Almost Anything Goes
    Last Post: 08-20-2008, 03:30 PM
