Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
    Aug 2006
    Michigan
    98 T/A
    WTF, on Gas Mileage
    Ok...
    9,000 miles or so ago, I changed the plugs (irridium GM) plug wires, Seafomed the intake and a can in the tank cleaned the throttle body, Cleaned the MAF sensor correctly, cleaned the air filter, changed the diff lube, replaced the fuel filter. 7k ago, I replaced the O2 sensors.
    I run a bottle of Seafoam through the tank every 6 weeks or so. Tire pressures checked every week.
    I am getting 280-290 miles a tank on a 98 T/A. 80% of my driving is freeway, and I do not rag on her. T56
    I did have a flange leak, drivers side, corrected 4 days ago. I have noticed the temp gauge barely creeps past 170-175, and it takes a long time to get there.
    Is there anything else I should or could look at? Would taking it somewhere(first time in 10 years) and having a diagnostic be worthwhile?
    I know she is tired with 139k, but she still idles well.
    Am I being a bi-atch complaining about this, or is this mileage normal?
    Kentucky
    2001 Trams Am
    I have talked to 4 people here in KY in the last week that have all seen a drop of 3 MPG.
    They are all over the state, so it isn't just a Louisville thing.
    Motorcycles, cars, trucks. My car is off more like 3.5 MPG.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    WTF. Im having the same issue. Always get at least 280 miles a tank. Getting like 180 now. Im really confused
    Aug 2006
    Michigan
    98 T/A
    Replace your O2 sensors... That was exactly my problem 8 months ago..No SES light at all..replaced both sensors up front by the motor and my mileage went from 180-200 to 300. Not as good as 330-340 that I used to get.
    I have a spare set of correct GM O2's if interested. They are the correct length and part #'s.
    Beaver Dam KY
    79 T/A -91 Firebird
    Doubt its the 02s since i changed them recently.
    Mileage drop basically happened overnight just as driven has explained. Changed out my IAT sensor and that helped a bit.
    Where do you guys fill up?
    Kentucky
    2001 Trams Am
    I use BP to get the 5% off.
    People I talked to use everything from Kroger to Shell. I know my stepdad uses namebrand premium.
    I wonder if they have slipped in some blended crap on us.
    Aug 2006
    Michigan
    98 T/A
    Which O2's? Are not there 4 of them? The two in the front are the ones I replaced.
    Still 180 per tank was what I was getting..Replaced the fronts, and after a few days, went back to 300 per tank.
    I had checked EVERYTHING else other than the o2's because there was no SES light. A few guys here said there were 4, but I replaced the front two in half an hour as Orion and SunsetOrangeSS suggested.
    I have never filled up with anything other than BP 93.
    Beaver Dam KY
    79 T/A -91 Firebird
    I only use bp premium. i have 1/16 tank of gas and i have to fill up in the next few minutes. Thinking of going to marathon.
    The rear two do nothing.. I dont have them.. no cats
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by Driven View Post
    its time for them to be changing over to winter blend at the fuel stations....i wonder if that is what is happening to everyone fuel mileage
    Beaver Dam KY
    79 T/A -91 Firebird
    Winter blend?
    Never had this issue since 05.
    mercersburg pa
    hugger orange
    2004
    Winter blend?
    winter blend is fomulated for colder weather and summer blend for warmer, they use different additives and ratios.
    i get my gas in maryland and pennsylvania and have seen a drop here in my mileage too.
    Kentucky
    2001 Trams Am
    I've never seen this happen before and I'm 27.
    Winter blend for diesel is the only chang eI know of. Gas would be a new thing.
    Aug 2006
    Michigan
    98 T/A
    I am on E now... Going to Shell and fill up. Will post results.
    I wouldn't doubt that alot of the premium still in the tanks is from the $4.39 a gallon days a few months ago.
    mercersburg pa
    hugger orange
    2004
    the diesel is less restricted in the colder months oey can use more anti jelling additives (like kerosene) to keep it from freezing in the lines.....yeah the man stuck it to us with gasoline blends too
    Kentucky
    2001 Trams Am
    I know all about diesel fuel.
    I've never heard of winter blend gas being used in KY.
    Member 01 SS Vert's Avatar
    May 2008
    Knoxville, TN
    01 SS Vert
    You gas just change to ethanol blended recently?
    Our did this year (up to 10% Ethanol) and I noticed 30-40 miles less per tank. I now shop at NON ethanol blended gas stations if I can find them.
    mercersburg pa
    hugger orange
    2004
    blended fuel is spreading like a disease....
    Kentucky
    2001 Trams Am
    Quote Originally Posted by 01 SS Vert View Post
    How do you know if they were or weren't selling blended?
    I see you're in michigan. Do you let the car idle a while to warm up? Keep in mind that your gas mileage is always going to suffer a little during the winter. The car takes longer to heat up and stays open loop longer so it uses a little more gas.
    in my Trans Am
    2000 Trans Am WS6
    dude the most i ever got was 218 miles to the tank.....i wouldnt complain about 280.......i also never run the tank down past a quarter full
  1. Gas Mileage
    By VOODOOII in forum External Engine
    Last Post: 08-24-2009, 08:10 AM
  2. Mileage
    By JwMonE99 in forum LT1
    Last Post: 01-27-2008, 05:06 AM
  3. LS1 Gas Mileage
    By LS1Powerhouse in forum Firebird / WS6
    Last Post: 06-29-2007, 06:14 PM
  4. bad gas mileage ls1
    By waylonSS in forum General Help
    Last Post: 09-23-2006, 04:10 PM
  5. 3.73 gas mileage?
    By jakef777 in forum Drivetrain
    Last Post: 09-11-2006, 01:07 PM
