    Member luciangage's Avatar
    tennessee
    94z
    shifter stuck?????
    i have a 94 z28 i backed the car out of the driveway then back in just rearranging my vehicles. When i went to move the car again the shifter would not go over into rev? this is the weird part after playing around with it the shifter seemed to go into all the other gears but when i let out on the clutch the car would ease fwd maybe an in. or so then stop like the ebrake was on? it did this even when the shifter was were neautral is supposed to be so i keep messing around and the shifter gets stuck now it wont move at all? i pulled the console and took the shifter out but that didnt help any ideas? i will pull the tranny out but i would like to have some ideas of what to check for before i start? thanks guys!
    tennessee
    94z
    anyone have even a guess or theory doesnt have to be right just a guess?
    Member Justin93's Avatar
    CANFIELD, OHIO
    PEWETER METALIC
    2002 CAMARO Z-28 M-6
    Sounds like what happened to me when my t56 took a dump. Get ready for a rebuild my friend. My problem was the shift forks binded and caused destruction of my synchros and it was stuck in 3rd. Good luck!
    Member Speed_kills_WS6's Avatar
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    The same happened to me. Totally blew my 3-4 slider up. I was getting stuck in 4th, and it would fall out of third. I annhilated my dogs in 3rd... The others in every gear were bent to hell. I only had to replace 700 bucks worth, but I went back with steel forged internals this time. Its the price you pay for bangin them gears, lol.
    CANFIELD, OHIO
    PEWETER METALIC
    Quote Originally Posted by Speed_kills_WS6 View Post
    Amen to that lol
    San Antonio
    Silver & Black
    99 Camaro SS
    If you really hadn't noticed odd shifting and banged through "rough shifts" I'd be looking at the slave cylinder.
    The inching you felt may be because it ain't going into reverse at all...you are almost in 5th.
    But the slave cylinders are notorious. Stop, breathe, pray a little bit....now go out and before you even start the car reach down and see if you can pull the clutch up. (If it comes up some it is a good sign.) Then, before you start, go ahead and press it in and "pull" the clutch up 3 times, PULL the clutch up, not LET it up.
    Then make sure you pull it UP one last time and then start the ole girl and give it a try. If this gets it did...congratulations...you are the proud owner of a bad slave!
    I think I damaged my 3rd gear synchro and broke my shifter before I knew it was my slave!
    tennessee
    94z
    it was just a brass bolt that comes in from the out side
    of the case and one roll pin cost me bout $15 from gm
  1. Shifter Stuck!
    By empire_942 in forum Automatic Transmission
    Last Post: 06-05-2010, 06:07 PM
  2. Stock shifter vs Hurst shifter
    By karpetcm in forum Drivetrain
    Last Post: 05-28-2009, 10:49 AM
  3. Factory hurst shifter & regular shifter?
    By importssuck in forum External Engine
    Last Post: 10-28-2008, 08:21 AM
  4. t56 shifter ? wich short through shifter
    By truckman in forum GTO
    Last Post: 07-26-2008, 06:59 AM
  5. 5.0 Shifter w/ Lou's short stick or just 5.0 Shifter
    By jrc1122 in forum Manual Transmission
    Last Post: 07-14-2007, 08:14 AM
