Thread: good deal on True Duals (TSP)??
01-12-2006, 07:25 PM #1Junior Member
- Nov 2005
Red- 1998 Pontiac Trans Am
I am buying a set of pacesetter long tubes and a true dual set up for my 98 Trans Am. I was wondering if anyone knew if some sponsors give you a deal if you buy the entire system (headers-back) from them??
Also, with that true dual system i was told that i should put new motor mounts in the car, what kind should i put in there and where can i buy them from?? thanks
01-13-2006, 01:23 AM #2minesfasterGuest
why would you need new motor mounts ?
01-13-2006, 10:27 AM #3member since may 2000
- Dec 2002
- n/w chicago
motor mounts??
none are needed for an exhaust2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
01-13-2006, 05:24 PM #4Member
- Burlington, NC
Black- 2000 Camaro SS
What Does Motor Mounts Have To Do With An Exhaust Sustem?
01-15-2006, 07:13 AM #5Junior Member
- Nov 2005
because with true duals, the x pipe will hit the floorboard everytime you get on it when the motor torques. with motor mounts it will be held in place a little tighter.
01-15-2006, 09:12 PM #6Member
- Burlington, NC
I have true duals with both pipes running down the passangers side where the original single pipe ran then goes over the axle where the single pipe ran. Neither of my pipes ever hit the floor board, nor the frame nor the axle nor the body and I have not changed the motor mounts. If you design your dual exhaust system right, it will fit right. Don't do a makeshift job. Do it right and you will be pleased with the end results.
new true duals
By LeadFarmer in forum Multimedia SectionReplies: 7Last Post: 08-30-2011, 03:19 PM -
WTB: True duals
By paulc87 in forum Parts Wanted / TradeReplies: 0Last Post: 03-21-2008, 03:01 PM -
this car seems too good of a deal to be true
By SLIM_DURST in forum Almost Anything GoesReplies: 12Last Post: 01-10-2007, 05:38 PM -
True Duals TSP
By JD_Z28 in forum External EngineReplies: 5Last Post: 12-02-2005, 05:53 PM -
True Duals in So Cal
By JD_Z28 in forum Western MembersReplies: 1Last Post: 11-30-2005, 06:48 PM
