Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 165
    Member Eric1987's Avatar
    Long Beach, California
    1999 Z28 Convert
    Lots of rain and big puddles=nononono
    So stupid me not really driving in rain much! I am coming back from the gym and I see a puddle so I slow down to like 10mph and try to drive through it. My call sputters and shuts off. I try to start it up and it shakes violently and I just shut it off. A tow truck guy pulls me out. I call my dad and he thinks it might be the altenator belt. When I try to turn it on now the dash just goes blank and thats it. No cranking or anything. I checked with a flashlight and I see a shiny part where a belt could of been. Right next to the LID like under it. What do you guys think? And how expensive is that belt?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Belt is very cheap/ Wouldnt cause it to shake violently. You dont have a form of cold air induction do you?
    Lets hope something is shorted out. and you didnt suck up some water and thrown a piston out the side of the block. Loosing any fluids??
    Check all battery connections and wiring. There is a lot that could have happened
    Cedar Rpaids,IA
    1998 Camaro SS
    I hope for you that it’s just the belt. Like JoshieDoom said hopefully you did not get any water in the engine, because if you try to start a engine with any water in the cylinders your are going to bend or break a rod which normally then cracks the block. General rule of thumb is if your car ever dies after you drove through a puddle never try to restart it! Tow it home, pull the spark plugs and let the cylinders dry out. It’s also a good idea to change the oil after all this as well.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    1999 Z28 Convert
    Well it seems like the altenator because it loses battery or so when I try to turn it on. No crank or anything now. I'll update you guys soon. I DID notice a belt look like it was missing though. It was hard to tell at night.
    odessa,texas
    69 hugger orange
    98 z28
    it is pretty easy to notice if the belt is there or not
    it sounds like the alternator/battery if the belt is still there
    1999 Z28 Convert
    Well I did notice the power steering was gone too if that makes any difference...
    Bragg NC
    Met. Sunset Orange
    01 SS
    Well regardless if the belt is there or not, It would still crank. First thing you need to figure out is why it wont crank. How deep was this puddle? Any mods? Did you try getting a jump or checking the battery for volts? May have fried the starter if it was deep enough, also check all your fuses and ensure your fuse box isnt puddled.
    You should have two belts, one for ac and one serp belt for all the Ass. Take a pic and post and we can tell you if its missing or not.
    J
    1999 Z28 Convert
    It was only up to my body. It wasnt even to my door. I could open my door without getting water inside the car. Only the free ram air mod. I am going to do all those things when my friend comes to pick me up right now.
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    sounds like you sucked up water, and have hydro locked the motor, if this is the case, its probably cracked the block./
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    weird...my car kind of did that once..when i was passing a car at night...no rain or anything tho....it shuttered like that all lighting in my car..exterior,interior everything went out.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    Ya, that was a pretty decent storm last night. I drove through a giant puddle and could hear the water slapping the floor of my car. I was going like, 5 mph and didn't have any problems.
    1999 Z28 Convert
    Quote Originally Posted by camarojunky74 View Post
    Yep thats what happened. Dont know about the block though. I know I got water sucked up. What does cracked block mean? My friend is going to fix it. I bought new oil, oil filter, spark plugs, air filter the whole schebang.
    Chicagoland
    1998 Z/28 LS6 crate
    It sounds very similar what happened to me back in September when we had some very heavy rain here in Chicago. I was going down the street and saw some water in the road. I slowed down below 10 mph and drove through it and got some water into the intake due to the free ram air mod. The car started shaking violently and I had the car towed. It turned out I hydrolocked the engine and bent the #7 connecting rod. Long story short I put an LS6 crate engine in it and haven't looked back. One of the most stupid and costly decisions I have made in my life. I hope you don't have the same issue.
    Chicagoland
    1998 Z/28 LS6 crate
    If you got water into the engine you are going to need a lot more than an air filter plugs and an oil change.
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    I'm gonna go ahead and say start looking for a new engine.
    1999 Z28 Convert
    Well if thats the case then you can say good bye camaro.....
    Beaver Dam KY
    79 T/A -91 Firebird
    Take out the plugs and disconnect the coils, turn it over and listen. Put plugs, in change oil and all that crap. Most likely you have fried the engine. But there may be a chance.
    1999 Z28 Convert
    Well I'll find out for sure tomorrow. Lets say it is a cracked block. I do NOT have the money to buy a new engine. What should I do? Dealers wont take it. I still owe my loan on it. Will gap cover it as a complete loss?
    Delaware, OH
    2001 GrandPrix GTP
    Insurance may cover it as an act of nature if you have full coverage. I'd notify them.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Give them a shout and see what they say. Once you get it to crank you will know for sure either way. You can also turn the balancer pulley with a wrench and see if the engine turns, if it does then its not seized.
    J
  1. Ram Air and Rain
    By LeadFarmer in forum External Engine
    Last Post: 10-10-2012, 10:13 PM
  2. Lots and Lots of Drag .... Racing I mean
    By Faught in forum Multimedia Section
    Last Post: 07-17-2011, 10:47 AM
  3. F1 in the rain??
    By snaggeltooth in forum Almost Anything Goes
    Last Post: 05-25-2008, 02:18 PM
  4. got wet in the rain
    By bulljock in forum External Engine
    Last Post: 10-24-2007, 08:42 AM
  5. I love Spring... Lots and Lots of Boobies!!!
    By 98-LS1 in forum Almost Anything Goes
    Last Post: 05-08-2007, 10:15 AM
