11-23-2008, 08:18 PM #1Slow'er'Ass
- Thornton, CO
Making 600RWHP N/A....With under 427 cubes
A very difficult task to take on.
Making 600RWHP, keeping the car fairly streetable, and using under 427 cubic inches.
I have seen ONE 402/408 make over 600 at the wheels without the use of nitrous or boost. And it was built VERY similiar to this one.
That is a VERY intense build.2001 Trans-Am WS6 M6
421 Iron Block
12.5:1
ETP 255’s
Rapid Motorsports Dominator Solid Roller Cam
Jesel J2K 1.7’s
Beck Sheet Metal Intake
Fast 90mm
Pump Gas
Kooks 1 7/8 x 2 x 3 ½ stepped headers with off road pipes
Kooks Y-pipe
Mufflex 4” catback
Textralia Twin Disk
D&D Viper Spec T-56
Denneys nitrous shaft
Moser 12 bolt, 4.11 gears
608rwhp 496rwtq
I know the 402/408 car that hit 600RWHP was also an M6, and also had a huge solid roller cam.
See a trend here?? Solid rollers, big cams, and hogged out heads will get you there. Also...the M6 is a requirement. No way an automatic will allow that magical 600RWHP number. Too much driveline loss. Granted, the automatic car will more than likely be quicker.2000 C5 Corvette
408 LS1 11.4.1 Compression HK Racing Engines
Greg Good Stage MEGA HP LS6 Heads 2.10 Valves
Custom Solid Roller Camshaft (Specs per Greg Good) around 250/260
Jessel J2k Rockers
Greg Good Ported FAST 90mm
Kooks 1 7/8 to 2" Headers
3" X-pipe
Textraila Exo Skel Dual Disc Clutch
Six Speeds Inc Stage 3 T-56 ( You da man Joe!)
DTE Stage 3 4.10 Rear End
19" HRE Wheels
MAFless Tune
This dyno is through open x-pipe. Through a B&B Triflow Catback it makes 578 RWHP!
601 RWHP 513 RWTQ SAE
The normal all motor 402/408 will make 475-525RWHP.
Mine is a perfect example.
402, Fast 90, 248/254 cam, Patriot stage III's, M6, heavy driveline.
531.1 RWHP
If the motor is built for a shot of nitrous (and cammed for it) it will lower the HP numbers as well when N/A. But run like a bat outta hell on the juice.
Just a little info to chew on.
If you have dyno/track results from 402-427 builds, please add them!! Be descriptive so we can see how you got there.
Ideas? Thoughts? Been a little slow in the internal section as of late.
11-27-2008, 12:36 PM #2
Any way this is possible with a hydraulic lifter cam?
11-27-2008, 12:42 PM #3Kenne-Bell Killer
- Oct 2007
- Lake Tahoe, CA
Cayenne Red, Pewter- '97 Z28 1LE #53, '02 WS6
Numbers could be there but it would never be "fairly streetable".
12-01-2008, 02:47 PM #4
Those torque numbers seem kinda low....any reason for that?
12-01-2008, 02:47 PM #5
12-03-2008, 03:08 PM #6
12-03-2008, 03:24 PM #7
12-06-2008, 07:37 PM #8
12-06-2008, 08:44 PM #9
yeah I'm an idiot....lol
Just rode in a 600rwhp WS6
By blackSS01 in forum Almost Anything GoesReplies: 47Last Post: 07-23-2010, 10:23 PM -
Help: looking for 600rwhp or more
By mk99z28 in forum Forced InductionReplies: 26Last Post: 03-06-2009, 07:15 AM -
By mk99z28 in forum Internal EngineReplies: 4Last Post: 02-17-2009, 06:30 PM -
For Sale: 1998 H/C/n2o Camaro Z28 600rwhp - $12.5k
By petebeale in forum Vehicles For Sale / TradeReplies: 4Last Post: 07-22-2008, 06:14 PM -
600rwhp, Turbo charged, 2001 Pontiac Firehawk FOR SALE!!
By dlevene in forum Vehicles For Sale / TradeReplies: 17Last Post: 09-25-2005, 12:30 AM
