Results 1 to 20 of 61
Thread: high idle only when moving
11-22-2008, 12:29 PM #1
Why is it when you are moving the idle is so high it is like having the cruise contol on? I have an 01 ss w/cam and a few bolt ons, m6 when you are driving the idle is very high but when you come to complete stop the idle decreases slowly to about 1000 which is fine but when you take off again it skyrockets. this is very annoying I can unplug the MAF and the idle is low and it does not do the idle up thing, but does run rich. tried different MAF and still doing the same thing. Oh and the car has been tuned but didnt start doing this until approx 6 months later. PLEASE HELP.
11-22-2008, 02:41 PM #2
My car does the same thing.
If you are driving down the road at say, 45MPH, and you push the clutch in or put it in neutral, it will idle at like 1400RPM. Then if you keep it in neutral and coast to a stop, the idle gradually drops back down to normal, at 1000RPM.
I think its a normal feature to keep the revs from dropping too much when you change gears at lower RPM's.
11-22-2008, 02:50 PM #3Senior Member
- Nov 2006
- Indianapolis
My car does the same thing, I think it is normal. Not that I like it, tho. It is worse when the engine is hot.
11-22-2008, 02:52 PM #4
It has to be a feature in the PCM, so I'm sure it can be tuned out somehow.
11-22-2008, 02:54 PM #5Senior Member
- Nov 2006
- Indianapolis
Agreed, it probably is able to be tuned out. Just wonder why they did it in the first place.
11-22-2008, 03:00 PM #6
My didnt start doing this till here recently and it is starting to get worse, it is almost like having cruise control on, and when you come to a stoplight everybody looks at upu like you are driving a promod car or something, it is starting to get real annoying...............
11-23-2008, 03:48 PM #7
Mine does the same thing! I hate it! However mine will go back down to normal if i blip the throttle (just tap it down about 1/4 throttle real quick) and it goes up (obviously) and then drops real fast down to normal 1,000. Try that and see what happens
11-23-2008, 04:07 PM #8
I will make sure i will try it, how long does it take for it to go back up again, I am willing to try anything right now
11-24-2008, 08:09 AM #9
It is a feature in the tune. You can eliminate it totally,,,I believe it's called throttle cracker in HPtuners. There is another table as well that will hold throttle up depending on MPH.
It's on both manual and auto cars.
You could stick mine in neutral and start rolling or coasting and as MPH picked up,,,,you could watch the rpms climb as high as 1,400 or so.
I agree, an annoying feature that uses gas if you do alot of coasting,,,and it also doesn't allow as much engine braking when letting off the gas. Thats what I can't stand about it,,,,you end up riding the brakes all the time while going through towns.
I eliminated it on both of our cars and it's much more pleasurable to drive.
11-24-2008, 01:28 PM #10Senior Member
- Nov 2006
- Indianapolis
"throttle cracker" LOL. Sounds racist!
11-24-2008, 03:52 PM #11
11-25-2008, 05:48 AM #12
11-25-2008, 06:25 AM #13
11-25-2008, 09:56 AM #14
11-25-2008, 11:11 AM #15
11-29-2008, 06:05 PM #16
12-09-2008, 03:01 PM #17
Knock on wood.... I think I might have found the prob, I turned the idle down by moving the idle set screw and everything SEEMS to be good i'm gonna drive it some more (weather pemiting) and see how thing go. I will let you guys know how things go as I get to drive the car.
12-09-2008, 04:39 PM #18
It may return. That throttle screw is just for baseline setting. It's actually the IAC [Idle Air Control Valve] that adjusts you idle airflow volume. The IAC is an electric stepper motor that opens a bypass port in the throttle body to let a measured amount of air past the throttle blade. I run a [FM1-F13-112 [+4] FMS Custom Grind Camshaft - 230"/232" .595"/.585" 112LSA - aggressive profile with a 2500-6800 RPM range, rough idle] cam and had the same high idle problem begin AFTER the car was dyno tuned. Took several trips back to get it right although it's still not perfect. If it was good before, check for trouble codes -not all trip your SES Light, maybe remove and clean the IAC? Maybe a temp sensor or lazy 02? If you cycle the mains on the ECM and it gets better for a while then it's coming from something the ECU is learning during normal use. Go talk to your tuner -they have dealt with this before and ought to give you something to go on.
12-22-2008, 04:23 PM #19Member
- Oct 2005
- San Antonio
Silver & Black- 99 Camaro SS
My 99 is doing the same thing. Idle is following cruise speed.
But only started after I changed from stock to a 92mm FAST TB and Intake.
Drives fine...brought it from WV to San Antonio...lost gas mileage.
I tell you I do not like the MAP sensor fit to the intake...I wondered how the Hell it couldn't leak when I put it in. We are warming up here in SA this week and I am going to get some car work done.
1. I am going to go leak hunting.
2. Check the MAP signal.
3. Then I'm going to shim the butterfly on the TB to make sure I'm not choking.
4. Then check IAC and MAF signals. If it comes down to it I am going to connect a potentiometer to these and then I will try amplifying the signal. (Very small steps of course.)
-But I think it is something w/ the MAP sensor.
12-22-2008, 05:31 PM #20
also could be your throttle positioning sensor
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
Rear End = High Pitched Noise While Moving
By theorangeguy in forum DrivetrainReplies: 20Last Post: 02-09-2015, 12:45 PM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 08:04 PM -
High Idle?
By bryceslu in forum General HelpReplies: 4Last Post: 03-19-2010, 07:11 PM -
high idle?
By hutch1999 in forum General HelpReplies: 11Last Post: 12-02-2007, 07:44 PM
