Results 1 to 20 of 21
Thread: Engine stand
11-16-2008, 01:16 PM #1Impounded
- Oct 2007
- Beaver Dam KY
Engine stand
Anybody built a engine stand for breaking in new engines? We have run ours for a couple of minutes at a time on the regular engine stand. I wonder what all would be required to do this..
Im thinking.. building a bracket for the radiator, a panel for oil pressure, coolant temp and hooking up an electric pump to circulate the coolant.
ideas?
11-16-2008, 01:25 PM #2
gasoline needs to be under quite a bit of pressure unless you are running an older carbd engine. thats a big stumbling block.
11-16-2008, 01:29 PM #3Impounded
- Oct 2007
- Beaver Dam KY
Yep all oldschool engines here. We got a 6 gallon fuel tank and the hose off the fuel pump run to it. works great.
11-16-2008, 01:45 PM #4
you should make the worlds first wooden engine test stand
11-16-2008, 02:00 PM #5Impounded
- Oct 2007
- Beaver Dam KY
haha im good. Basicially all i need to do is pump a electric pump that could keep a engine cool.
Anybody got any really cheap ideas??
11-16-2008, 02:58 PM #6
I've seen guys just adapt a garden hose to the coolant inlet and let the water go w/o actually recirculating the warm water, works to keep the engine cool to make sure it runs but i doubt its good for break-in as the motor never would warm up.
11-16-2008, 06:55 PM #7Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
Have you ever heard of an engine dyno?? they can break in engines on that too...and also have source for coolant, and all gauges and accessories required for the engine
11-16-2008, 07:05 PM #8Impounded
- Oct 2007
- Beaver Dam KY
Not looking for a 25k dyno. Just something to rig up to keep engines from overheating and seeing them run and etc.
Something I can build for 50 bucks. lol
11-16-2008, 07:12 PM #9Senior Member
- Jul 2006
- Greene, Iowa
my old shop teacher in high school made one...he used 1 inch square tubing and built a cradle for the motor...built a "gauge cluster" out of pllywood...wired all his gauges. and did a simple plug and play to the motor and would crank it every so often. doubt it could be built for under 50...maybe around 100 or so...gauges will be the biggest part unless u goto autozone or somehwere and get those cheap ass sun pro gauges or whatever their called...they come in a pack of 3...oil, ammeter, and water...and buy a tach ontop of that ull be set
11-16-2008, 07:14 PM #10Senior Member
- Jul 2006
- Greene, Iowa
oh..and get a cheap radiator and electric fan set up to help keep the engine around operarting temp...could be had pretty cheap at a junk yard
11-16-2008, 07:40 PM #11Impounded
- Oct 2007
- Beaver Dam KY
Got all the crap. Just need to mock it up and find a good fluid plump.
11-17-2008, 10:51 AM #12
Maybe some car out there came with an electric water pump from the factory that you could score at a junkyard?
11-17-2008, 09:11 PM #13Impounded
- Oct 2007
- Beaver Dam KY
I wonder how much the cheapest electric pump for a SBC would cost? I have a brand new k5 blazer radiator(big bastard) and all the oil guages etc. My dad likes to dick around in the shop a lot ever since I got him back into racing. He cant do much since hes had heart surgery so I thought I would build something for him to play around with. He does header swaps and carb swaps and intake swaps and lets in run for a few minutes at a time just for the entertainment. Thought it would be a good part of an xmas present
11-17-2008, 09:42 PM #14
dude, just get an actual water pump and rig up an electric motor to run the waterpump.
why cant you just run a belt from an actual waterpump to the crank?
11-17-2008, 09:44 PM #15Impounded
- Oct 2007
- Beaver Dam KY
We thought about that but there is long/short SBC pumps and all the pulleys are different. Tried it..
11-17-2008, 09:52 PM #16
rig up something like this
http://www.jegs.com/i/Mr.+Gasket/720/4333/10002/-1
11-17-2008, 09:59 PM #17Impounded
- Oct 2007
- Beaver Dam KY
thanks for the link. I didnt know they were that cheap
11-17-2008, 10:04 PM #18
just bust apart a vacuume cleaner and use the guts to make one yourself. It would be cooler that way.
11-17-2008, 10:24 PM #19Impounded
- Oct 2007
- Beaver Dam KY
haha im good
11-17-2008, 10:27 PM #20
dude, what kind of redneck engine stand are you trying to build if you cant build it out of wood and use a vac. cleaner to power the waterpump.
in Alaska, that part would take 4 weeks to show up in the mail, and when it shows up you would have forgotten what you ordered it for in the first place.
DIY Engine Break-In Stand - Stand Delivered, Part II
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 02-17-2011, 01:00 PM -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 01-20-2011, 01:30 PM -
start up on engine stand
By olds powered in forum General HelpReplies: 0Last Post: 04-12-2010, 03:55 PM -
Engine Stand
By lmyers1 in forum General HelpReplies: 1Last Post: 03-27-2008, 04:11 AM -
Engine stand bolt size for ls1
By 95GreenZ28 in forum General HelpReplies: 1Last Post: 06-26-2007, 11:48 AM
