Thread: wont start, cant pop clutch
11-16-2008, 07:56 AM #1
After work last night it was probly around 20 degrees, coldest its been so far this winter. I put the key in and turned it, radio and dash lights all came on, and brightly too, not dim. Car would not turn over or click.
I tried pushing it and popping the clutch (in second gear b/c ive never been able to pop it in first) and it fired up for just about a second, and as soon as it fired up it started to die so i put the clutch in and gave it a little gas, but then it died out. pushed it back up the parking lot and tried again, same results.
I'm going to check the battery terminals today and even get a new battery (what kind do I get?)
WHAT ELSE COULD BE THE PROBLEM???
Any help is greatly appreciated.
11-16-2008, 09:33 PM #2
that was easy...
i used a can of compressed air and blew a whole lot of dust and crap out of the key hole in the ignition.
started right up. still gonna check the battery though.
11-16-2008, 09:35 PM #3Impounded
- Oct 2007
- Beaver Dam KY
Hmm never thought of the canned air in the ignition to clean the VATS sensor.
Glad you got it fixed
11-17-2008, 11:54 AM #4Senior Member
- Feb 2006
- Orange County, NY
If you get any battery I would get an optima. Seems like you got the problem fixed. Was the security light on when it wouldnt start?
11-21-2008, 07:59 AM #5
icant remember, it must have been. also got the batt tested, still has plenty of life apparently.
Thanks for the help guys.
11-23-2008, 03:52 PM #6Junior Member
- Jul 2007
- Portland, Oregon
Red- 2001 Camaro SS
You might want to get a spare starter relay as well... I had the same problem this week, and I think that was my problem. Couldn't hurt to have one in the glove box, as it's the same part number for the starter, ignition, and both cooling fans.
11-23-2008, 04:31 PM #7
Hah yeah i had the same problem too. Starter died though
12-13-2008, 05:22 AM #8
Mine started doing this again this week. Now, the dash lights won't come on so, I'm now suspecting that the ECM is bad again.
I had this changed when this all happened this last spring. Was driving and then all the dash lights went out and the gages went to zero.
After they changed the ECM, this fixed it for about most of the year but, now its back. uh!
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
ls1 wont start
By FutureWS6 in forum General HelpReplies: 4Last Post: 07-02-2010, 08:07 PM -
Help: please help this POS LT1 wont start!!!!
By antivenom2001 in forum LT1Replies: 3Last Post: 10-18-2008, 06:37 AM -
Car wont start......
By zul8r2002 in forum General HelpReplies: 4Last Post: 07-28-2007, 02:20 PM -
my car wont start
By keyto123 in forum General HelpReplies: 6Last Post: 06-17-2007, 05:21 PM
