    Member slpdablueZ28's Avatar
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    maximum size wheel on stock suspension?
    wats the biggest rim size, plus tire u can run on a stock suspension? im currently running a 275/35/17 tire. so 17 by 9.5 rim. wat would be the biggest rim diameter and width wise that would fit including a decent tire combo that wouldnt rub on the wheel wells. run a bigger rear smaller front? suggestions on wat would look bad ass?
    Member blk_jaws's Avatar
    Eastern, Kentucky
    Black on Black
    2000 Trans Am M6
    I would say all the way up to 20" in height but I would never go past 17", anything bigger than a 17 just dont look good IMO
    I would say 11" wide for the back would be as wide as you could go but not for sure, 315/35/17 I think
    SLP LT's, SLP High Flow Cats, 3" Flowmaster CB, Comp Cam, SLP Lid, LS6 Intake, BBK 80mm TB, SFC, Ram Air HO Hood, Lowered, Torq Thrust II's
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    11 wide is the widest all the way around the car that I've seen 17x11 with 315-35-17 on all four wheels.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    The 19" wheels/tires on the 2009 ZR1 Corvette look BA.... I'm thinking of installing a set on my SS.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    wheel diameter makes no difference.....its the tire u put on it........max TIRE size ive seen is 315 on 10.5 or 11 inch wide wheels..........PM eugenoss as he runs wide ass tires daily and when he takes it to the track.........305s or 315s all the way around
    Member crazy dave ls1's Avatar
    Aug 2008
    texas
    2002 z/28
    '04 z06 wheels 17x9.5 front 18x10.5 rear. 275/40zr17 front 295/35zr18 rear
    Delaware, OH
    2001 GrandPrix GTP
    I've seen 325/40/17's on a couple but they were still on a 17x11 rim and 28 inches high.
  1. Stock wheel stud size?
    By Speed_kills_WS6 in forum Wheels and Tires
    Last Post: 08-01-2010, 07:19 PM
  2. Question: what size tires can I fit under stock suspension?
    By SmokinSS in forum GM Trucks
    Last Post: 03-25-2010, 06:13 PM
  3. Wheel Spacer Size For Stock Wheels WS6
    By TheGimp711 in forum Wheels and Tires
    Last Post: 01-28-2008, 03:00 PM
  4. Maximum Wheel Size?
    By KiD WiCKeD in forum Wheels and Tires
    Last Post: 04-16-2007, 08:57 AM
  5. Stock Wheel Size Question (2001 Z28)
    By jshilli1 in forum Wheels and Tires
    Last Post: 04-24-2006, 07:26 PM
