Results 1 to 20 of 30
    Nov 2008
    Newark,Delaware
    1994 Trans Am
    LT1 lookin 4 advice on upgrades
    I have a 94 Trans am. looking to do some work on it. As of right now i have ZR1's on Front" 275/40?/17 and Rear: 315/35/17 lookin to make some power to use those big tires. lookin at LT4 intake and heads. Hotcam kit. Anything else u guys thinking?
    Turbo Member yellowlt1ta's Avatar
    Jan 2008
    Orlando, Fl
    yellow
    93 Trans Am
    It all depends on how much power you ultimitly want and how much you got to spend. then you can decide were to go with it.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    +1
    What is your price limit, power goal, and what do you want to use the car for?
    Also are you an automatic or 6 speed?
    300RWHP, 341RWTQ
    1/8 mile 8.32 at 83.97
    1/4 mile 13.049 at 105.24
    Nov 2008
    Newark,Delaware
    1994 Trans Am
    I got a 6-speed and im lookin to get a high 12 second car out of it. I wanna pretty quick daily driver. money isnt really a problem at this point. LT4 heads and intake. Hot cam kit. new pulleys. main things im lookin at now
    Nov 2008
    Newark,Delaware
    1994 Trans Am
    ill even take 13's to get my cousin from running is mouth about his piece of crap 5.0
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    If thats the case then yea the LT4 should be fine.
    If you buy the LT4 kit, go ahead and get the heads and intake ported before you install it.
    BTW you should be able to take a 5.0 no problem even stock.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    and if you get pullies make sure you get the set that comes with the alternator pully as well. With justa regular one, the alternator would not charge up enough. You can get the set from summit for like 80 bux.
    Kenne-Bell Killer Cayenne97's Avatar
    Lake Tahoe, CA
    Cayenne Red, Pewter
    '97 Z28 1LE #53, '02 WS6
    Unfortunately GM Performance Parts does not offer the complete LT4 Package anymore. You can still get the LT4 Cylinder Heads, as well as the standard LT4 cam or "HOT" cam upgrade, but not the original intake. Edelbrock does however offer their version of the LT4 intake.
    For the money I would skip the LT4 setup altogether. A more cost effective solution to what you wan't would be the LE1 heads & cam kit from Lloyd Elliot. It will put you right around 370rwhp with an M6, long-tube headers, 58mm TB and a good dyno tune, for about $1200 + the cost of supporting bolt-ons.
    97 Z28 1LE #53 11.08/122.84 N/A, 9.82/131.06 150-shot
    02 WS6 M6, STOCK H/C/I, 3189 lbs., 11.77/113.02 (1.59 60')
    08 Mercedez C63 AMG, FOR SALE!!!
    http://www.ls1.com/forums/showthread.php?t=108586
    Member side2000's Avatar
    md
    2000 camaro ss
    if money ain't a thing get 210 AFR's and then build a motor around 'em.
    2000 red ss: >2" drop, koni adjustables 'n 275 s-compounds all way around, giant brakes, dynatech LT's, borla catback (no plate), t56, tubular everything, HARD TOP, caged, "stock" heads 'n a mean cam. -2* front camber.
    Nov 2008
    Newark,Delaware
    1994 Trans Am
    yea ive been looking at several different options. however body work has now come into play because i took a deer out doing about 80mph. a buddy on mine is doing the body work so that wont dent me to much.
    and stock 5.0's are no problem both my cousins have the same exact one. however one is a 5 speed with some bolts ons and spray. the other is stock aod. suck the stock one up easy. and not to far off the other except for when he sprays. my main goal is to get a good 13 second pass all motor.
    When im a the track my problem is hooking i have bad 60 foots like 2.6 and my 1/4 time is at best so far 14.4 at 102mph thats spinning through third. I just got new tires but the deer screwed up my track visit :-(
    md
    2000 camaro ss
    Quote Originally Posted by HondaEater94 View Post
    i dunno how your insurance is but i hit a deer in my car AND my cummins and hitting a deer is the only thing that's covered that doesn't raise my insurance. check it out before ya drop a bunch a loot on fixin's.
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Sorry to hear about the accident. Do you wan't 12's or 13's? If 13's is all your after than just get yourself an intake/cat-back, and practice getting that 60-ft waaay down.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    The lt4 setup can get him into the 12s as well.
    You would just need to do some porting to the LT4 heads and intake
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Quote Originally Posted by JwMonE99 View Post
    An LT4 kit with supporting bolt-ons and tune would run 12's right out of the box!
    I'm all for the LT4 setup if he's willing to dish out the xtra dough. The LT4 has it's advantages, like a stronger midrange and better driveability when compared to a built LT1 setup. But their pricey. For much less a Lloyd Elliot kit or a setup from Advanced Induction could be had.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Very true, but I can get the LT4 kit and Loyd Elliot for about the same price.
    LT4 being a little bit more of course but then again you dont have to wait 3 weeks either.
    Lake Tahoe, CA
    Cayenne Red, Pewter
    If I remember correctly isn't the LT4 heads/cam package over 2 grand? Plus you have to factor in the cost of the intake manifold. I know the LT4's can make some crazy #'s. I've ridden in a AFR 210-headed 385 LT4 '96 'vette that pulled like a MoFo. I've just always like Lloyds products. I ran the LE1.2 on my last LT1 car and made some really good #'s while maintaining emissions in CA.
    Oct 2001
    Colorado
    95 Z28
    LT1s have gone into the 11s with only bolt ons... been done more than once.
    md
    2000 camaro ss
    Quote Originally Posted by Cayenne97 View Post
    i jsut got finished buildin a 396 LT a little while ago and it put down 440 horse twistin to 6800 under some 210 AFR's and a ported LT4 man. those 210's really are sweet. (if 2100 bucks for heads is not outta your price range.)
    Lake Tahoe, CA
    Cayenne Red, Pewter
    Quote Originally Posted by side2000 View Post
    Yes the AFR's work wonders on LTx motors. Unfortunately I haven't had the chance to use them, although I do have a set of 'extinct' Canfield LT4's that are quite similar.
    Nov 2008
    Newark,Delaware
    1994 Trans Am
    ive been shoppin around looks like im gonna be gettin the cam from summit if i cant find a cheaper one. and a buddy on mine has an intake. just gotta find some heads.
    And insurance is covering the accident. and rates arent going up so im pretty happy about that.
  1. 98 Trans Am 6-speed (doing upgrades need advice)
    By black_98TA in forum Firebird / WS6
    Last Post: 05-11-2010, 05:27 PM
  2. Lookin for advice
    By p_funk22 in forum Firebird / WS6
    Last Post: 07-27-2007, 11:39 PM
  3. Please Advice on UPGRADES.
    By Candice in forum Internal Engine
    Last Post: 06-14-2007, 02:02 PM
  4. Newbie lookin at upgrades on LS1
    By stvszm1 in forum External Engine
    Last Post: 10-28-2006, 11:31 AM
  5. advice on performance upgrades.
    By jhopdawg in forum Firebird / WS6
    Last Post: 09-01-2005, 02:09 AM
