    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Moser 12 bolt owners...please come in
    How bad does your rear end cover leak. I know a few ppl that said that a little fluid keeps comming out of the rear. Is this normal? Would another cover possibly fix the issue?
    Member cuzimoto's Avatar
    Feb 2008
    Newport Beach
    99 Formula
    No leaks from mine, I've had it for 4 years made several hundred passes with M6 and some auto cross.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by rajiv1998 View Post
    Is the fluid coming from between the cover and the differential case??
    If so, sounds like it just needs to be resealed. I'd try using Permatex Ultra Black gasket maker instead of the stock paper gasket, its very effective at sealing.
    Severna Park, MD
    Quote Originally Posted by Wesman View Post
    Concur, I just sealed a Gen 2 10-bolt that leaked forever w/the black w/Permatex and it is finally sealed.
    Member MnLS1's Avatar
    Jan 2008
    SW Metro, MN
    1999 SS
    not a drop here. +1 for the permatex
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Mine leaks, Im resealing it and not using the stock GM gasket.
    Probably had a jack placed under cover at one time, never do that... guaranteed to leak after that.
  1. moser 12 bolt
    By T-TOPS in forum Drivetrain
    Last Post: 04-15-2008, 12:50 PM
  2. Moser 12 Bolt
    By gumby1682 in forum Drivetrain
    Last Post: 06-18-2007, 08:54 AM
  3. Moser 9" owners...fluid change ??
    By Mr. Luos in forum Drivetrain
    Last Post: 05-04-2007, 05:13 PM
  4. WTB. 12 Bolt Moser.
    By CharlieSS in forum Parts Wanted / Trade
    Last Post: 04-17-2006, 11:59 PM
  5. WTB: Moser 12 Bolt
    By 02IKND in forum Parts Wanted / Trade
    Last Post: 10-10-2005, 05:14 PM
