Results 1 to 1 of 1
Thread: Need 350 Trans advice.
11-06-2008, 05:39 AM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I have a 77 camaro with a 350 trans in it, The car have a bad vibration in it starting at 70 mph. I have done a lot of things to get raid of it but nothing has worked.I have installed new ujoints,had driveshaft checked for balance,I have installed new frame mount brushens,changed rearends,driveshaft yoke,and torque converter.Is there any way the trans could be causing this problem?The trans has been rebuilt,but I can't recall if it was doing it before it was rebuilt.I have done everything but replaced the trans. need new ideals I have run out of them.I also had all tires checked and balanced,I had axles checked, and like I said I have since changed the rearend and the problem is still there.
98 Trans Am 6-speed (doing upgrades need advice)
By black_98TA in forum Firebird / WS6Replies: 29Last Post: 05-11-2010, 05:27 PM -
Help: need trans advice (bad bad noises)
By Fury_786 in forum Manual TransmissionReplies: 0Last Post: 07-02-2009, 06:34 PM -
New member, 2nd Trans Am, Could use some Advice
By Styke in forum Firebird / WS6Replies: 1Last Post: 04-17-2007, 08:05 PM -
About to buy a trans am need advice!!!
By GEARBANGER in forum Firebird / WS6Replies: 11Last Post: 03-20-2007, 11:33 AM -
Advice on automatic trans am
By fastassbird05 in forum Automatic TransmissionReplies: 1Last Post: 02-18-2007, 09:51 AM
