Results 1 to 3 of 3
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    no power when turning or engine bogs bad!
    When i take a full left or right turn and give it a about part throttle, the car just chugs along very slowly. I can then punch it and it does absolutely nothing! like the cars sta a stand still. It will eventually grab and go, but its never done this before and lately its been pretty common. any ideas?
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    You've got what kind of car again?That sounds like a weird one to me-I had an old truck that had a similar deal-when you went around a right hand turn it would die-finally figured out that it was a hole in the radiator tank,when you went around a turn-it would splash antifreeze out the hole and spray down the coil.It would dry off enough to restart in a short while due to the engine heat-I couldn't crank it and watch the engine at the same time so it took a while to figure out.Not saying this is what your problem is- just an interesting story that illustrates how you have to think outside the box on some of this stuff.Let us know if you figure anything else out.
    igofast Brandon35thSS's Avatar
    ALABAMA
    red with 35th le stripes
    2002 35TH LE
    i had a truck that did the same thing. would almost die when id let of the throttle to turn or at a stop sign or a light and it was the fuel filter. if its been a long time or you havent replaced it yet probably a good idea anyway
  1. zr-1 Vs evo evo bogs off the line
    By xcelr8 in forum Kill Stories
    Last Post: 05-11-2010, 06:53 PM
  2. car bogs at mid throttle w/detonation
    By sic2001 in forum General Help
    Last Post: 05-07-2008, 05:46 PM
  3. Replies: 10
    Last Post: 10-08-2006, 08:50 PM
  4. 96 LT1 Bogs under light load??!?
    By silvernuke in forum LT1
    Last Post: 09-02-2006, 09:12 AM
  5. 3200RPM, temp gauge flat lines & engine bogs out
    By third_shift|studios in forum General Help
    Last Post: 02-19-2006, 03:38 PM
