01-10-2006, 02:18 AM #1Junior Member
- Sep 2005
- New Jersey
- iTrader
- 0
white- 1995 LT1
95 Z28 with a Forged 383 stroker! 11's in 1/4! One of a kind! Pic's Inside!!!
Hello, I have for sale a 1995 Camaro Z28 with 56,000 mile on the chassis and about 2,500 on new stroker motor. I have all documents on the motor and everything else I bought for it. I spent over 7,000 alone on the motor: We had the motor in my buddies trans am just to see what it was capable of. Since his chassis was set-up for 1/4 mile and his motor was out he put mine in and made 10 passes. His car weighs 3600lbs. It went 11.70's all motor. With 100 shot of NOS it went 10.70's. Since this motor was design to go with a F1 PROCHARGER and he has one for his set-up we put it on, with the a good tune with the FAST system it went 9.515 @140.71mph with a 1.333 60ft and a 6.052 1/8 @113.87 on only 14lbs of boost, it carried the wheels soo nice. I have video and all the timeslips! He used my motor to run in a mustang shoot out and won! Needless to say the car is fast enough for me on motor alone, so I never added a Procharger!
LT1 Forged Short Block Assembly for Blower application:
4bolt main, with ARP studs and windage tray
4340 Forged steel eagle Crank/4340 hbeam rods
Custom SRP Pistons with a -31.000cc Piston dish(Adjusted compression raito 8.95)-3/16plasma moly rings
LT1 hand ported heads, race valve job, 2.02/1.60, ARP rocker studs guideplates, double valve
Comp cams custom grind cam .540 intake/.573 exhaust lift
springs to match camshaft requirements
Extreme duty roller rockers - hardend push rods
ARP head bolts
Intake port matched
36lb accell injectors, also have 75lbs injectors incase you decide to supercharge it!
Corsa Cat-back
SLP Headers and y pipe
373 gears with T/A stud girtle
18 in Z06 wheels
Crossdrilled and slotted rotors
*Computer tuned for current set-up
This this hauls A$$!!!!!!!
Interior is all leather charcoal Gray and in excellent condition!
Crazy 3,000 watt surround system with dvd play and 7inch LCD!
Body is completely Custom never seen one like it! It was sprayed with house of colors White. Shaved door handles, Custom doors and Quarter Panels. Ground affects were customised and molded into the bumpers. Custom headlights and custom Toyota Supra Tail lights also! SLP UltraZ hood that has been smoothe out! All the lines in the car have been filled to give it a smoother, sleaker look!
and alot of other custom work! Have to see Pic's! Everyone loves this car!
Please email me for more pic's at [email protected]
Asking 17,500 OBO!
Attachment 2247
Attachment 2248
Attachment 2250
Attachment 2251
Attachment 2252Last edited by jmangler; 01-15-2006 at 05:58 AM.
01-14-2006, 04:40 AM #2BlueCrickett
- Sep 2005
- Port Huron/Michigan
- iTrader
- 0
Teal- 1994 Trans Am LT1
Stick or auto? T-Tops? How much do you have into the other custom work of the car?
01-14-2006, 05:23 AM #3Junior Member
- Sep 2005
- New Jersey
- iTrader
- 0
white- 1995 LT1
It has a built auto with heavy duty clutchs,corvette servo's, shift kit and 2,800 stall.
Originally Posted by dan_48422
It has T-Tops.
I have over 30k into the car alone. I will send pic's to you if you want, just send me an email.
01-15-2006, 05:38 AM #4Junior Member
- Sep 2005
- New Jersey
- iTrader
- 0
white- 1995 LT1
Ttt
01-17-2006, 01:12 AM #5Junior Member
- Sep 2005
- New Jersey
- iTrader
- 0
white- 1995 LT1
Ttt
03-13-2006, 07:35 PM #6Junior Member
- Mar 2006
- Erie,pa
- iTrader
- 0
sunset orange- 1996 formula
I would love to hear a clip of how this sounds from idl and hard take off.email [email protected]
Searching for Forged Stroker Crank
By JAKEJR in forum LT1Replies: 6Last Post: 11-10-2010, 08:09 AM -
1995 LT1 383 stroker troublshooting
By steiger99 in forum LT1Replies: 15Last Post: 11-16-2009, 05:48 PM -
1995 stroker/turbo'd Trans Am
By 95TA383 in forum Vehicles For Sale / TradeReplies: 0Last Post: 07-23-2007, 03:42 PM -
Custom Built LT1 383 Stroker Motor
By 2000camarokid in forum Parts For Sale / TradeReplies: 1Last Post: 09-27-2006, 11:56 AM -
Custom Paint 1995 T/A
By Pyromaniacal in forum Member's RidesReplies: 14Last Post: 08-21-2006, 11:44 AM
