Results 1 to 17 of 17
    Bawlz Deep andrew rs's Avatar
    gold
    2000 honder accord
    Got Really Bored
    And put a Realistic Dream car together
    2002 Pontiac Fire Hawk 4,752 Mi. 6 speed=$29,500
    Heads+Cam 226/226 112lsa Patriot ported LS6 59cc Heads=$1895.00
    Headers Hooker 1-3/4 Long Tubes Ceramic Coated=$659.95
    Y Pipe Hooker Ceramic Coated= $299.95
    Cat Back Bassani Tru dual with x pipe=$901.55
    Fast 92/92=$1249.99
    Shifter Hurst Billit Plus= $199.00
    Moser 9in rear end with 3.89 gears=$2250
    Clutch Spec stage 3 700lb ft.= $449.99
    SLP air [email protected]
    Shocks Konis=$819.95
    Springs Eibach pro kit= $239.95
    BMR sfc=$169.95
    Brake pads=$150
    Wheels Chrome Y2K corvette wheels 18x9.5 17x8.5=$829.00
    Tires BFG kd295 35 18=$315.00x2
    Tires BFG kd275 40 17=$245.00x2
    $40824.24
    450Rwhp
    TNT Nitrous Kit 125hp =$799.99
    $41624.23
    575 rwhp
    Quarter Mile
    O.C. California
    2002 Camaro SS (crashed)
    I'm bored too, so I shall edit for you.
    (2002 Camaro SS t-top 6,100 mi, full brake in 6spd)
    (heads agreed, cam 226/229 114, port match to manifold and blending)
    ADD- engine blue printing and balance,Pully kit, Messier water pump, 4 core alum Radiator, Turn-one power steering pump, oil & PS coolers, TPS fuel pump and booster, MSD kit)
    (Kooks, long tube, coated inside and out, flange blending)
    (Kooks Y-pipe, with cats, coated inside and out)
    (stock SLP center dual tips)
    Fast 92/92=$1249.99
    (FAST 92/92, port matched and painted, plumbing for Direct Port nitrous by ED)
    (B&M pericous, cut 1')
    (Strange 12 both 3.73, high spline, carbon driveshaft, ABS retained, blanced)
    (Exedy twin carbon, drilled steel flywheel and balanced, Z06 slave and master cyclinders)
    ADD Tranimission rebuilt kit to stage 2
    (volant)
    (agreed but single adjustable)
    (strano)
    BMR sfc=$169.95
    (agreed but damond series)
    ADD UMI full kit
    Brake pads=$150
    (wilwood 6 piston conversion, with 2 piece slotted rotors, ss line and proportioing valve, line lock)
    (CCW 10, black center with polished lip 18x9.5 18x11)
    (nitto invo)
    $40824.24
    450Rwhp
    (nitrous express, 175 wet)
    $41624.23
    575 rwhp
    Quarter Mile
    (2002 SS 6spd) SLP lid & scoop,NX wet kit & maf, NGK-TR6,160',MSD,Kooks LT & y-pipe,SLP Dual center exhaust,cut-out,tuning SUSPENSION Chromoly k-member, Chromoly adjustable upper and lower a-arms,koni s-adj,Eibach sport springs,Wilwood brakes,SB,BSK,TA,TAB,SFC,PHB,ST,18x9.5&18x10.5, Nittos
    Philly+Glenmoore, Pa
    Pewter Metallic
    2002 Trans Am WS6 M6 D1SC
    Fast 92/92=$1249.99
    (volant)
    (strano)
    BMR sfc=$169.95
    ADD UMI full kit
    Brake pads=$150
    (nitto invo)
    $40824.24
    450Rwhp
    $41624.23
    575 rwhp
    Quarter Mile
    Go ahead and tack on like 15 grand more for yours,
    I am right around $40K into Slowass total now....
    531RWHP, probably enough for 10's at sea level.
    Pewter Metallic
    Ill believe it when i see it!!
    Winter Garden, FL
    1999 Camaro Z28
    That has to be the Grand Am we all know your Trans Am couldn't do that.
    Pewter Metallic
    Im sorry, I should of specified.
    Ill believe it when I see it!
    You and me both.
    gold
    2000 honder accord
    what supporting mods would need to be doneto that car if I built it?
    Powerstrokin LT1 > LS1's Avatar
    Aurora IL
    Trans Am owner
    former
    Quote Originally Posted by andrew rs View Post
    fuel pump, msd ignition, ported, shimmed ls6 oil pump, LS2 timing chain, fluids, roll cage,
    thats all I can think of in like a minute......I might come up with more.....oh yeah, 4 or 5 point belts.
    gold
    2000 honder accord
    Quote Originally Posted by LT1 > LS1 View Post
    good call, Im only 20 and that car would probibly get me hurt if i didnt have one of those.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    rebuilt t56, arp rod bolts or new long block after it drops a rod and blows up at the 1000ft mark, injecters springs and shocks sway bars .....#1 mod need in this case driver mod
    Aurora IL
    Trans Am owner
    former
    Quote Originally Posted by blackbirdbrain89 View Post
    chromoly following: lca's, subframe connectors, panhard bar, torque arm, and k-memeber.
    those are important. keeps wheelhop away......no one likes wheelhop
    btw, I heard new injectors and fuel pump come with procharger kits.....or is it just the pump?
    anyways, just thought of more. FAST fuel rails, fuel pressure regulator, air/fuel gauge (wideband), boost gauge,
    and if you are THIS serious about building a car to this level......go ahead, and do things right the first time.....get some stainless header. spend the extra $500 or so, and it will be SOOOOOOOO worth it.... last thing you want is a beautiful enigne.....and rusty headers.....
    gold
    2000 honder accord
    Im not building it with a procharger... if I do even build it. This is all hypothetical... I am not in any position to drop 40k on a car right now... but in a year to year in a half I will be.
    Member totalkos's Avatar
    New Orleans
    Nbm
    y pipe, cat back, and bassani true duals with x pipe all in one car? how you gonna fit all that under there?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Im like 14k in mine total..... get a new dd and well see 40k
  1. Got bored
    By lancesT/A in forum Camaro / SS
    Last Post: 04-28-2009, 08:52 PM
  2. Can a 5.3 be bored over?
    By FORMULA7 in forum GM Trucks
    Last Post: 03-15-2007, 03:56 PM
  3. Bored...
    By DanWS6 in forum Rocky Mountain Members
    Last Post: 03-04-2007, 08:25 AM
  4. bored
    By issues in forum Almost Anything Goes
    Last Post: 08-13-2006, 09:56 AM
  5. forged and bored VS bored stock block
    By third_shift|studios in forum Internal Engine
    Last Post: 05-15-2006, 06:33 PM
