Results 1 to 18 of 18
Thread: 1 7/8th for stock internal?
10-26-2008, 10:22 PM #1Junior Member
- Aug 2007
- australia
hey im currently running 1 3/4 long tube 4 into 1 headers with a 3 inch collector. i was wondering if changing to a 1 7/8 primary would give any top end gains on a stock internals ls1? setup is fast 90/90 (to be ported) and fitting a meziere and 25% udp. thanks,
Jake,
10-27-2008, 04:38 AM #2
I believe above 3000rpm the gains are around 8hp going from Pacesetters to TSP 1 7/8ths according to TSPs dyno comparison.
10-27-2008, 04:22 PM #3Junior Member
- Aug 2007
- australia
Thanks for that, exactly what i was after! seems like a worthwhile gain to me! although 3 hp would have as well!
Jake,
10-27-2008, 04:54 PM #4
Just to let you know, there was a small loss of torque below 3000rpms though...
10-27-2008, 04:59 PM #5Slow'er'Ass
- Thornton, CO
I don't think the gains are worth it...unless you are able to sell the ones you have for a decent amount.
If you are geared properly...they will shave off a little of your ET.
10-27-2008, 05:00 PM #6Junior Member
- Aug 2007
- australia
Thats cool, im racing stock internals so the car doesnt drop below like 5000rpm!
Jake,
10-27-2008, 05:02 PM #7Junior Member
- Aug 2007
- australia
They should only cost me about $600 au which is about $300 us to you guys at the moment!
Jake,
10-27-2008, 05:07 PM #8
10-27-2008, 05:18 PM #9Junior Member
- Aug 2007
- australia
stock heads and cam. m6 with 3.9 for street and 4.11 with a spool for track.
Jake,
10-27-2008, 05:21 PM #10Slow'er'Ass
- Thornton, CO
I would say the 1 3/4" headers are perfectly fine.
I didn't even consider the 1 7/8" until I up'd the cubes.
10-27-2008, 05:28 PM #11Junior Member
- Aug 2007
- australia
Would i gain any thing above 4000rpm? im chasing times at the track. will be changing engines later in the piece but want to run a 10 sec stock internals first!
Jake,
10-27-2008, 05:33 PM #12Slow'er'Ass
- Thornton, CO
A full 1/4 mile?
Supercharger? Nitrous?
10 second with stock heads and cam requires a power adder.
Is the timing/length different down under?
10-27-2008, 05:39 PM #13Junior Member
- Aug 2007
- australia
Yeah its the full 1/4 mile. No power adders allowed and no nitrous either! Its not impossible the current record here in australia is 11.07. I read on another forum of a guy with a firebird who ran a 10.6x stock internals, which is amazing. at the moment ive run an 11.4 and still have lots of ways to remove weight and add a bit of power here and there, and at the pointy end 3-5hp is huge. here is a profile on my car
http://www.gmmotorsport.com/gm_ls1toy.shtml
Thanks for you help.
Jake,
10-27-2008, 05:55 PM #14Slow'er'Ass
- Thornton, CO
Very cool car!!!
What does it weigh?
You would probably get 6-7RWHP (my guess) above 3500-3700 RPM's with the larger primaries.
10-27-2008, 06:05 PM #15Junior Member
- Aug 2007
- australia
Thanks mate! its basically like a gto but with a tub in the back.
out of the factory it weighs about 1600 kg or 3550 pounds. but with some light weight parts i am getting and have got it should be around 3000 pounds or so. its got irs suspension which doesnt help launches but, i have done a 1.6 60ft on the 3.9 and am chasing a 1.5 with the 4.11 and less weight maybe a high 1.4
ive got a broken arm at the moment so i cant drive it but im hangin to get back out there.
Jake,
10-27-2008, 06:25 PM #16Slow'er'Ass
- Thornton, CO
Good luck on those ET's.
That is MOVING for a stock internal car.
I like the Ute's.
10-27-2008, 06:51 PM #17
TSP did the test on a completely stock motor with the exception of the fact that it had a Fast intake. Other than that it was bone stock.
10-28-2008, 01:30 AM #18Junior Member
- Aug 2007
- australia
Looks like a goer then! thanks for you help guys!
Jake,
Question: hids..internal or external
By SteveCZ28 in forum Appearance SectionReplies: 3Last Post: 08-27-2010, 06:24 AM -
Help: 3.4L forged internal kit?
By adrenalinejunkie in forum V6Replies: 30Last Post: 05-18-2009, 07:18 AM -
internal resonance
By grouch0jr in forum Firebird / WS6Replies: 16Last Post: 03-28-2008, 11:23 AM -
Internal Engine Problems?
By Pappa Doo in forum Internal EngineReplies: 4Last Post: 08-12-2007, 04:43 PM -
FS: stock internal and external stuff
By Robinator in forum Parts For Sale / TradeReplies: 5Last Post: 09-14-2005, 05:03 PM
