Thread: Wiper motor
    Member Pete Rock98's Avatar
    Bronx NY
    1998 z28
    Wiper motor
    Yesterday my wipers got stuck in the up postion so I did a search and the threads said bad motor .Today I bought a new wiper motor, at what position do you put the dial? What direction should I place it on the bracket and motor?I swapped it out 4 times moving the dial and still no luck the wipers are not in the right postion .
    Thanks
    Bronx NY
    1998 z28
    The problem started after using the wipers they would park almost straight up when shut off. After the new motor was installed they would park OK when off but when using the Delay function they would park straight up between delay strokes. I tried 2 rebuilt motors .What postion do you set up the dial(the crank arm assembly) the piece that is mounted to the motor and connects to the wiper linkage. 12 or 3 or 6 or 9 O'clock.
    This is crazy 2 days trying to fix this.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Are you sure the motor is bad? My wipers did the same thing and I cleaned off all the connections and they now work fine.
    Bronx NY
    1998 z28
    I'll will try contact cleaner on the harness connector .The oem motor was returned for a $25 core charge.
  1. Bad wiper motor?
    By Ramairgod84 in forum General Help
    Last Post: 10-01-2009, 05:35 AM
  2. Bad wiper motor?
    By Ramairgod84 in forum Corvette
    Last Post: 09-30-2009, 12:20 AM
  3. Help: Wiper motor relay
    Last Post: 09-29-2009, 05:32 AM
  4. Wiper Motor
    By SilverFish in forum General Help
    Last Post: 08-10-2008, 05:29 AM
  5. Wiper Motor
    By 1badtk in forum General Help
    Last Post: 07-10-2007, 04:42 AM
