Results 1 to 20 of 22
Thread: with coolant question!
08-14-2015, 06:50 AM #1
Hey everyone well long story short i sold my 2000 trans am 6 years ago and just bought it back again. Going thru all of the fluids this morning as i wasn't able to last night because it was dark the oil and trans fluids all look good. But when I pop the radiator cap i don't see any fluid. I see residual of fluid so i know there is some in there but shouldn't it be filled to the top of the radiator? Or should I turn it on and let it warm some first (not fully to operating temp) and than i'll see the fluid. also there is some discussion on here about what color antifreeze to use....if it's green should i stick with that one and top it off? as we all know there isn't any pontiac dealers left to buy dexcool so where else could I buy it if it is in fact red? thanks for any help!~Chris
08-14-2015, 07:35 AM #2
If its green, stick with green. If its orange, stick with orange. They also make a universal antifreeze for both colors, but I don't like to mix it up. The level of fluid should be at the top of the radiator. I normally pull the cap off when the car is cold. Start up the engine, then fill it to the spot where the hose coming off the throttle body meets the radiator. It's just below the opening of the cap. When you reach operating temperature and the cooling fans come on, your good. If you over fill it while its warming up, you will lose a little fluid when the car begins to warm up. Also check the level in the overflow bottle. There are measurements on the overflow bottle dip stick for both hot and cold levels.
08-15-2015, 07:50 AM #3
Even with Pontiac gone, GM is still GM. Go to any GM dealer and they should be able to help you. That or look in the manual for what type of coolant it takes and google it, order it online. I personally feel the reservoir should always have fluid in it because that is the back up fluid incase any leaks or burns out, aside of being the obvious point that something is low. I would look really well for any leaking or have an oil analysis done.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
08-15-2015, 10:24 AM #4
couple things.....like someone pointed out you can still get dexcool all over the place. I personally just run a global type in all of my vehicles but that's just personal preference. If you can't see antifreeze then you're in fact low. Now my question would be where did it go? Need to see if you have any leaks and where the missing fluid is going. Dexcool doesn't tolerate contamination very well.
08-15-2015, 10:37 AM #5
thanks for the input Orion, i am sorry i didn't update this thread earlier. It did in fact have some coolant in the overflow jug that is an orange color so it is definelty Dexcool. I was able to buy some 50/50 dexcool here at the local Napa to top off the radiator, it took very little for it to get to the top so i believe that it hasn't been checked since I sold it back in 2006......long story short i sold this car 9 years ago to somebody in san diego......was at work last week just screwing around on craigslist, typed in 2000 trans am and wouldn't you believe it to my surprise the guy i sold it too 9 years ago put it up that very same day.....hard to believe I know but i was floored....called him told him i'd pick it up in an hour and the rest is history.....he only put 9,000 miles on it in 9 years.....told me the wife got tired of just seeing it sit in the garage.....so i bought it back.......so i'm guessing the lack of antifreeze was just from lack of maintenance......now on a side note.....my trans am has 373 gears.....and the rear diff has a slight leak.....any suggestions on what fluid to use in the rear end when i pull the diff cover and refill and reseal it?
08-17-2015, 04:12 AM #6
I used Royal Purple synthetic gear oil back when I installed my Moser 12 bolt, well over 10 years ago. Have had zero issues with it, So thats what I recommend.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
08-17-2015, 07:32 AM #7
I went through the same thing a couple of months ago. Found an 02 CETA with 13,000 on it. First owner only 7500 in 12 years. Second owner 6000 in 6 months. I have a mechanic friend who works at a large Chevy dealership. Took it to him to change and flush all the fluids so that I would have a base point to start with. I also had him replace the fuel filter..
It took me about a week to get a coolant level that I thought would be correct. 3 time out of 4, when I removed the cap the level would be down 4-5 inches. Almost took a flashlight to see it. Filled it to the neck and would run until good and hot. Check next day cold and down again. Finally got overflow tank at the cold level and level in tank would vary between right at the overflow tube and 4-5 inches down, but so would the level in the overflow tank. Even now the level in the tank will very when cold from right at the overflow tube to 4-5 inches down. But, if the level is 4-5 inches down in the tank, the level in the overflow is a little above the cold level. So it appears that a level between the overflow tube and 4-5 inches down is pretty normal as long as you have some in the overflow tank. Also, 4-5 inches down is not a lot of coolant.Last edited by RCH33; 08-17-2015 at 07:37 AM.
08-17-2015, 10:32 AM #8
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I think that these overflows allow evaporation, I've had multiple times where the cooland level dropped, the latest was a few weeks ago when my heat gage spiked, and I had to put about 100 oz of water in it to keep the level up to get a coolant flush. I've had this car pressure tested multiple times and no leaks, no coolant in the oil, and no sweet smell or wetness in the passenger floor side.
Of course, Orion could have been draining it out whe. He was taking my wheel center caps
08-17-2015, 02:32 PM #9Boost gets you laid, unless your name is Jon.
08-17-2015, 03:36 PM #10
08-17-2015, 05:10 PM #11
what weight? and will i have to add any addative when doing the refill? and how much do the 10 bolt rear ends take?
08-17-2015, 07:04 PM #12
Here is the link on car maintenance I wrote in 2011. It's in the General Help section (stickied).
http://www.ls1.com/forums/f6/general...1/#post2564198
Rear Axle - Standard Differential
Use SAE 75W-90 Synthetic Axle Lubricant (GM Part #12378261 or equivalent meeting GM Specification 9986115).
Change every 30,000 miles
Rear Axle - Limited-Slip Differential
Use SAE 75W-90 Synthetic Axle Lubricant (GM Part #12378261 or equivalent meeting GM Specification 9986115). With a complete drain and refill add 4 ounces of Limited-Slip Axle Lubricant Additive (GM Part #1052358 or equivalent). Even though the 2000 model year and later F-body limited-slip differentials are a gear type Torsen unit, the use of a limited-slip additive is still recommended.
08-17-2015, 07:34 PM #13
Thanks 35th. Kinda of a dumb question but how do I know if mine came with the limited slip? I had 373 gears installed. Would they have removed it?
08-17-2015, 07:58 PM #14
08-18-2015, 05:56 AM #15
I prefer the "road stripe test" for posi-traction.
08-18-2015, 07:01 AM #16
08-18-2015, 07:07 AM #17
08-18-2015, 10:09 AM #18
Ah yes, Jeff's way is a little more fun lol.
08-19-2015, 09:28 AM #19
YEP, What pajeff02 said. I like to "check" my posi out just about every time I drive it. You can never be to sure, always best to double check. LOL
08-19-2015, 12:09 PM #20
LS3 coolant filling question
By Gobs in forum General HelpReplies: 6Last Post: 01-13-2013, 04:44 PM -
Question about coolant temps
By km346 in forum Computer & TuningReplies: 6Last Post: 07-26-2010, 11:26 AM -
Ls6 coolant tubes question
By km346 in forum External EngineReplies: 40Last Post: 04-27-2010, 07:23 PM -
Fuel and coolant question. PLEASE help.
By TransAmcoupe98 in forum External EngineReplies: 7Last Post: 10-08-2007, 07:50 PM -
Coolant question
By burnout in forum General HelpReplies: 10Last Post: 11-09-2006, 12:54 PM
