Results 1 to 10 of 10
Thread: Stall speed?
12-15-2008, 06:09 AM #1
- Sep 2008
- Huntersville, nc
Red- 2001 Camaro z28
Stall speed?
Does anyone know the factory stall speed for the 4l60e in a '01 camaro z28
12-15-2008, 02:41 PM #2
- Groveland ,FL.
Silver- 1998-Camaro SS
Stall Speed for 01 Z28
I believe the stall speed for the 4l60E in a 01 Camaro Z-28 is 1700. I've heard from several people if you go higher than 2500 Stall, you're car will feel like it's slipping. Also a Trans. cooler should always be installed.
Scott
12-15-2008, 02:59 PM #3
12-15-2008, 03:08 PM #4
Probably a TCI converter then
Those things are notoriously tight.
12-15-2008, 04:39 PM #5
12-15-2008, 05:05 PM #6
- Sep 2008
- Huntersville, nc
12-15-2008, 05:32 PM #7
12-17-2008, 03:33 AM #8
Stock stall is rated @ 1650 RPM.
SteveC
12-17-2008, 07:27 AM #9
LOL, not a bad guess eh?? I have ran a few TCI converters and a transmission as well in the past. Had a bad experience with the trans I won't get into,,,and the converters always seemed a little too tight for what I wanted to do. Came to find out I wasn't the only one. So I steer away from TCI now. Converters aren't terrible though if you can get away with a tight one.
Probably works well with your combo since you have a cam with minimal duration and the lobes are spread out to 114,,,that really helps to smooth things out a bit and tames the converter requirement down considerably.
My wifes car has slightly less duration than yours,,but the lobe sep is tightened to 112,,although a 6 speed,,,I could get away with a stock stall with this cam if I wanted to,,,I have it tuned now to the point where it sounds like a stocker,,,baby smooth. Sorry to get off subject, just interesting stuff to me.
12-17-2008, 11:00 AM #10
What stall speed are you running?
By Ed Blown Vert in forum Automatic TransmissionReplies: 160Last Post: 12-16-2015, 07:34 AM -
Which Stall Speed Would Best ?
By Redrokit8 in forum Automatic TransmissionReplies: 16Last Post: 03-06-2013, 05:53 PM -
need some advice on stall speed
By DemonSpeed in forum Automatic TransmissionReplies: 3Last Post: 11-07-2008, 07:43 AM -
How does the stall converter behave, does the car move below stall speed?
By 99bluebird in forum Automatic TransmissionReplies: 15Last Post: 07-02-2007, 01:49 PM -
What stall speed for this setup?
By 02 super sport in forum Automatic TransmissionReplies: 11Last Post: 02-18-2006, 06:09 PM
