Results 1 to 16 of 16
Thread: my car is shaking
06-11-2010, 08:23 AM #1
- May 2010
- chicago area
green- 1997 camaro base
my car is shaking
alright so i have the money to do the performance upgrades i want to do now. but now the front end is shaking at low speed. any ideas as to what could be wrong?
06-11-2010, 10:41 AM #2
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Tire out of balance, brake caliper sticking, warped brake rotor, loose lugnuts, engine misfire, ect.... Could be a lot of things - need more input.
06-11-2010, 10:57 AM #3
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Bent rim?
06-11-2010, 11:09 AM #4
Possibilites,,,Hung caliper pin, tie rod ends, ball joints, wheel weight fell off, bad dampers, broken or missing stabilizer linkages,and the afore mentioned..
06-11-2010, 03:26 PM #5
If only at a certain speed, I would guess it's something related to your wheels.
06-13-2010, 02:30 AM #6
- May 2010
- chicago area
yeah its only at around 15 mph. Sorry ive been working a lot havnt had time to come on since i posted this. but yes it is only when i am around 15 mph and cant feel it at any higher or much lower speeds
06-13-2010, 05:39 AM #7
15 mph? imho..Hung caliper pin and a warped rotor due one pad riding the rotor and the pad not fully seating on the rotors surface. Samething happened to me a couple of years ago. I had a siezed caliper pin.. Pita to get apart too.. Does it shake under hard braking? When was the last time you lubricated the pins?
06-13-2010, 01:25 PM #8
- May 2010
- chicago area
yeah it likes to drift to one side wile breaking. the next thing that i thot is im probably just not noticing it at high speeds but it always drifts to the left. and i would doubt that they have been lubed in a while the guy that had it last didnt take very good care of it.
06-13-2010, 02:11 PM #9
06-13-2010, 02:55 PM #10
- May 2010
- chicago area
should i get it fixed before adding the new exhaust and intake?
06-14-2010, 03:00 AM #11
06-14-2010, 06:25 AM #12
06-14-2010, 06:45 PM #13
- May 2010
- chicago area
alright so this will be the first on the todo list.
06-30-2010, 02:45 PM #14
- May 2010
- chicago area
update just a bad tire
07-01-2010, 05:35 AM #15
07-01-2010, 06:05 PM #16
- May 2010
- chicago area
yeah you called it
Question: Vibration and Shaking
By manibot in forum Manual TransmissionReplies: 5Last Post: 02-16-2010, 04:25 PM -
What's shaking
By Golicous in forum New Member IntroductionsReplies: 3Last Post: 05-20-2009, 01:23 AM -
Violent Shaking
By TheKitchenSink in forum Automatic TransmissionReplies: 4Last Post: 06-13-2007, 08:23 AM -
steeringwheel shaking only at 55
By ou812 in forum General HelpReplies: 2Last Post: 04-14-2006, 09:06 PM -
shaking?
By Fast95Bird in forum General HelpReplies: 1Last Post: 10-08-2005, 01:34 AM
