Results 1 to 20 of 31
Thread: studdering and almost stalls
11-09-2009, 12:07 PM #1
- Jan 2006
- Shepherd, Michigan
howdy
so here is the deal...when my car (a4) is put into gear...the RPMs occasionally dip below 500 and the car sputters and almost dies. or when its just idling in park it will just briefly stumble a little bit as described above. This happens maybe 2-4 times a week...and when it shows these signs in idle when i put it in gear (usually reverse) it will do it too..but just that 1 instant...then its smooth sailing
so what do you think guys ? its sporadic and has me scratching my head
now that i think of it ...this might belong in the trans section possiblysorry mods
11-10-2009, 12:53 AM #2
That can be tuned in the idle section, where it say in park / in gear / with or with out AC ect... Might just need bumped up some, and you might want to crack open the TB plate a little. The idle control might be maxing out.
I guess I assumed you have HP Tuners ?
11-10-2009, 05:16 AM #3
11-10-2009, 06:26 AM #4
My car does the same thing, shop said part of it was the stall, Im still running stock, but plan on moving to a 3400 or 3600 soon. When mine does it it will actually kill the car in reverse.
11-10-2009, 10:16 PM #5
If you need a VCM flash, it will be free. Just thought I would let you know.
11-11-2009, 04:55 AM #6
11-11-2009, 04:57 AM #7
11-11-2009, 08:00 AM #8
what mods do you have shady? I forget. Sounds more like an air issue to me. Anything been done to the car lately in the throttle body/air intake area?
11-11-2009, 08:54 AM #9
- Nov 1999
- over here...
is the car in open or closed loop when it happens???
11-11-2009, 09:00 AM #10
Don't forget the obvious - Fuel Pressure.
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
11-11-2009, 09:05 AM #11
11-11-2009, 09:06 AM #12
11-11-2009, 09:09 AM #13
- Jan 2006
i am going to double check around my mani and TB ..but nothing has changed...i might clean my maf too
something else weird i have been noticing lately..is that my revs "hang" when i give it a blip..it will sit at that rpm for about 1 1/2 seconds so if i blip it up to 1.5ish ...it will jump to 1.5k then sit there for almost 2 seconds then slowly drop back to 600ish
i dont really notice a performance issue ..but its just something i would like to know the cause from ya know.
11-11-2009, 09:09 AM #14
11-11-2009, 09:44 AM #15
11-11-2009, 09:46 AM #16
I agree with Spaz
11-11-2009, 09:46 AM #17
- Nov 1999
- over here...
could also be a spark plug... one car i looked at back in 99 had custom headers and had melted a plug wire...
11-11-2009, 09:49 AM #18
melted plug wires are common. Broken wires are also common. The type that you can't see where the carbon core is actually split.
11-11-2009, 10:11 AM #19
Mine did the same and it was a wire. but also when I floored it it misfired in the upper rpms
11-11-2009, 11:23 AM #20
- Nov 2009
- Shepherd MI
Silver, Stealth Gray- 97 SS CLONE, 06 GP GXP
jordon we need to make sure that you still do NOT have a vacuum leak still> since we never had issues before we got that LS6 intake mani on there. and fuel pressure would be a good check too (x2) .
Help: Car Stalls, jerks, goes..stalls
By Oldsmobileman in forum General HelpReplies: 5Last Post: 07-08-2016, 03:30 AM -
help with studdering
By RealLiveMD in forum Computer & TuningReplies: 54Last Post: 02-23-2010, 01:58 PM -
studdering after WOT
By RealLiveMD in forum Computer & TuningReplies: 8Last Post: 08-16-2009, 12:47 PM -
serious engine studdering all of a sudden
By jmatt07 in forum General HelpReplies: 23Last Post: 06-25-2009, 05:50 AM -
Help: T/A stalls out
By 02superfly in forum General HelpReplies: 21Last Post: 01-18-2009, 06:02 AM
