Thread: heads question?
02-27-2008, 04:27 PM #1
- Jan 2008
- texas
White- 99Trans am
heads question?
I have already started my cam install and i was woundering what to do with the heads (or should i leave them alone)? my cam specs: Any help will be appriciated.
Valve Setting:
IN./Hyd.
EX./Hyd.
RPM Operating Range:
1800 to 6600
Duration:
Advertised IN./.287 EX./.287
@.050" IN./224 EX./224
Valve Lift:
1.7 Rocker: IN./.545 EX./.545
Springs: LS1
Lobe Sep. Angle:
114
02-28-2008, 09:16 AM #2
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
Make sure you change the valvesprings. Other than that, I would leave the heads alone.
02-28-2008, 09:27 AM #3
03-01-2008, 03:25 PM #4
- Jan 2008
- texas
White- 99Trans am
well its to late. they said they were going to do pocket work mill the valves and do a 3 angle valve job and polish the exhaust side something like that he said i would be happy of the way they are going to come out? i dont know do you think its worth the money?
03-01-2008, 03:46 PM #5
03-01-2008, 04:03 PM #6
get some comp 916 beehieve springs and hardened pushrods, you wont regret it
03-02-2008, 11:43 AM #7
- Jan 2008
- texas
White- 99Trans am
i have slp high flow oil pump, slp double roller timing chain, comp cams hi tech hardened pushrods ls7 lifters and rev dual valve springs .650 max lift. I just didnt want to leave the heads alone and then regret not doing something to them does anybody have experience with stock heads being machined? Any suggestions and reply will be appriciated?
03-06-2008, 05:49 AM #8
- Jan 2008
- texas
White- 99Trans am
03-13-2008, 02:14 PM #9
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
How much are you paying to get all the work done to the heads?
03-14-2008, 08:10 AM #10
- Jan 2008
- texas
White- 99Trans am
03-14-2008, 08:44 AM #11
- Jun 2006
- Ft. Lee, Virginia
sounds like a good deal.
03-14-2008, 10:19 PM #12
- Nov 2005
- Victoria, Australia
Shanghai Mica- 2001 HSV SenatorSignature
A mill to bring the compression up may also be a good thing for you.
Cheers,
MaccaOne of HSV's finest:- http://www.cardomain.com/ride/2221327/1
Heads Question.
By black04gto in forum Internal EngineReplies: 16Last Post: 11-25-2013, 05:38 PM -
question on heads
By bluehawk2000 in forum Internal EngineReplies: 15Last Post: 11-30-2009, 03:35 PM -
heads question?
By 99w69kitt in forum Internal EngineReplies: 0Last Post: 02-27-2008, 04:27 PM -
Heads question
By JwMonE99 in forum Internal EngineReplies: 8Last Post: 02-24-2008, 06:20 PM -
PP stg 2 heads and cam question
By 98formy in forum Internal EngineReplies: 6Last Post: 01-16-2008, 05:42 PM
