Thread: u joint??
10-25-2011, 04:23 PM #1
u joint??
Ok, so I'm driving along and everything is fine, and I'm going like 60-70 and I let off the has and if I push it again ill hear this rattle or grinding sound.. its not my cats or trans mount, just replaced all of that. My mechanic thinks it might be my u joint.. opinions?? Driving a 2001 trans am btw
10-26-2011, 08:18 AM #2
- Jan 2009
- North Jersey
Are you experiencing any vibrations? When was the last time you serviced the rear end? It could be a number of things. Torque arm, U-joint, rear end, etc. You also mentioned you replaced the trans mount. Did you tighten the crossmember?
10-26-2011, 09:12 AM #3
Yeah, I did. It sounds like its coming from up front tho.
10-26-2011, 09:16 AM #4
- Jan 2009
- North Jersey
And the shifter isn't moving at all. Correct?
Also, are you running headers? If not, check your manifold heat shields. They could have rusted off the bolts and are rattling.
10-26-2011, 09:22 AM #5
I'll have To check that then, ill let you know later today, thanks
u joint help
By SilverBulletLS1 in forum DrivetrainReplies: 4Last Post: 01-16-2014, 07:06 AM -
So tell me about my u-joint
By goof4080 in forum DrivetrainReplies: 3Last Post: 07-03-2012, 03:44 PM -
Question: Bad u-joint???
By joedude02 in forum General HelpReplies: 2Last Post: 11-02-2008, 09:09 PM -
U-Joint
By 01CalgarySS in forum DrivetrainReplies: 3Last Post: 09-18-2008, 05:43 PM -
U-joint squeaking?
By B200 in forum DrivetrainReplies: 0Last Post: 08-10-2007, 06:58 PM
