Results 1 to 11 of 11
10-23-2012, 10:40 AM #1
- Oct 2012
- Grand Rapids, MN
Navy Blue Metallic- 1998 Chevy Camaro Z/28
vibration increases with speed under heavy accel.
Hey guys, im new to the forum but im on my 3rd LS1 '98 Camaro Z28 and ive grown fanatical about these cars over the years and im trying to make this particular car perfect so help with this issue would be great....if i mash the gas at 70 or so and it climbs to 80, then 90, then 100.....110...and so on, i feel like the driveshaft has a vibration some where or something.... like it vibrates as its turning and you can feel it...idk...ive thought about maybe 3rd gear is vibrating but you can almost feel it on the tail shaft of the tranny or something...idk what it is.....any ideas or common mounts or anything that need replacing?
(Car has SLP intake, K/N filter, LS6 intake, 3 bar maf, cat-deletes,EGR and full emissions delete, 900cc battery, E3 plugs, SLP 160 stat, a/c belt delete, SLP stage 2 "loud-mouth" cat-back, 17" ZR1 rims-9.5w-10.5w, 3.42 Auburn posi, ALL sythetic fluids-otherwise stock)
10-23-2012, 10:56 AM #2
Have you checked your trans mount and u-joints?
Lt's,SFC,3,600 Fuddle stall,Spohn Adj. tunnel mount torque arm, BMR LCA,Ls6 intake,Air lid,Under drive pulley,S60 rear,Frost tune and a few more things I cant remember.
10-23-2012, 05:21 PM #3
- Jun 2011
- Branchville, NJ
^^^^ ditto^^^^
10-23-2012, 05:49 PM #4
You could also be feeling a stutter if you are "mashing" it in 6th gear. Your car doesn't have enough ass to push it forward all too well in 6th at those speeds. Otherwise, I'd suggest what was mentioned; u-joint and transmission mounts.
10-24-2012, 09:12 PM #5
U-Joints !
10-25-2012, 05:29 AM #6
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
Just another thought here, but I'd also check the balance on your wheels/tires, too. I had a vibration pop up not too long after I bought my car that was fairly pronounced when driving it at highway speeds. A trip to my tire shop turned up a bad right front tire. Something to consider, at least. As mentioned above, I'd look at U-joints, also.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
10-25-2012, 10:36 AM #7
- Oct 2012
- Grand Rapids, MN
Alrighty, Thanks guys...i really appreciate the feed back! I'll throw in a set of new U-Joints and a poly' trans mount and ill get back at ya
10-25-2012, 11:55 AM #8
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
You might inspect the driveshaft as well, and make sure it's still in balance.
10-26-2012, 08:33 AM #9
- Mar 2006
- WI
- Blog Entries
- 1
My bet is on a tire out of balance seeing it doesn't go away. Check for junk stuck inside the wheels and tire treads.
10-26-2012, 12:20 PM #10
Why are you going to just change the joints, that may not even be the problem at all............
Why would tires only have a issue under load, tires don't change under load ??????
Look at the torque arm make sure it is tight, no broken bolts or anything loose.
Check the mount, it seems as if only under hard use you get a issue (since you ONLY said when MASHING the gas leading us to believe you have NO issue anytime else) and only under hard use will anything driveline related change.
11-22-2012, 03:38 PM #11
- Oct 2012
- ardmore oklahoma
yellow- 2004 pontiac gto
u joints or possibly the nut that hold the rearend yok on and gears tight could be loose enough to cause a vibration.
Hot Rod To The Rescue - High-Speed Driveshaft Vibration
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-01-2014, 02:11 AM -
Tax increases !!!
By redls1 in forum Political / Debate ForumReplies: 27Last Post: 12-31-2010, 07:51 AM -
Bad vibration at high speed?
By yellowv in forum General HelpReplies: 13Last Post: 04-15-2007, 05:46 PM -
Heavy vibration after Trans. mount install
By WS_SEXY in forum General HelpReplies: 8Last Post: 05-21-2006, 03:56 AM
