Results 1 to 14 of 14
12-14-2009, 10:24 AM #1
- Dec 2009
- Camden, South Carolina
Citrus(burn't) Orange- 2001 Camaro SS
Torque Converter...(HOW MUCH STALL??)
hey i have a 2001 camaro SS and of course its an AUTO.
but i just ordered a MS3 cam and i was wondering how much stall i needed. just enough to get back with the cam is really all im looking for. I really dont want anything huge! i was thinking like 2000-2500.
Any idea's?
12-14-2009, 10:47 AM #2
- Aug 1999
- Arizona
That isn't worth it. Go at least 3000-3200.
What is the powerband of the cam?
12-14-2009, 11:26 AM #3
That is a top end cam 3200-3600 stall would be better. Our torque converters have lock-up op so don't worry about driving around on the freeway at 3000rpm.
12-14-2009, 12:03 PM #4
I'd get a 4000
12-14-2009, 12:14 PM #5
12-14-2009, 03:02 PM #6
I'm running a 3,800 stall in my daily driver.
we run lock-up stalls so you can get away with a higher stall and a decent tuner can make it pretty tame.
for the cam your looking at 3,800-4,000 stall.
but look at it this way, if you take a all stock motor and run a 3,500 stall you can drop .5 second off your 1/4 mile time
12-14-2009, 03:40 PM #7
not knowing your orther mods, hard to guess, how high you going to wind it? think that cam should make power to 67-6800 rpms, 35-3600 stall should hold your shift extensions up to 5-5500
I run 4k yank last , holding shifts about 6k on moter, have a yank 4400 waiting on the floor if I want more
good luck. JohnnyY2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
12-15-2009, 02:56 AM #8
- Dec 2009
here is the powerband for the MS3 cam "2300-6800 RPM Power Band with a peak around 6400rpm" ok i have a better idea of how much stall i need, but what is a good brand and is somewhat a good price??? And since it will be my DD i will need lockup....
12-15-2009, 04:35 AM #9
I'd say you need a minimum of a 4k stall w/ a cam that big. I have a much smaller cam and run a Yank PT 4000 stall in my DD as they're very drivable. What about induction and exhaust mods? Probably need some 3:73s as well. What's the goal for the car? We definitely need more info to help you with your decision.
12-15-2009, 11:31 AM #10
Tell us your goals and I'll give you a better idea of the stall you want.
I'd personally go with a 4000 or higher with that cam, but that's just me personally. This is going to completely change your car, it will run like a raped ape after you get a GOOD tune. A tune is very important with a cam and a stall.
Yank makes a good converter but they are about 750-900. Circle D makes a good converter as well, I think they cost a bit more. I've heard people use Vig as well. Those might be a bit cheaper. I personally have a Yank.
I bought the best transmission cooler I could find, very important to keep the temperatures down in the transmission. It'll get a lot hotter running that stall. There is a lot you need to learn yet, if all I am saying is new to you. The stall is gonna kill gas mileage, not only does it take more power to go around town, but you won't be able to keep your foot out of it because it's such a joy to drive. Once you get to about 50mph or so, depending where the tune is set to "lock up" the converter...then you will get decent mileage on the highway and such.
12-15-2009, 12:17 PM #11
I know with mine (04 a4 GTO) in the computer there are a few mode settings that can be activated for the transmission.......normal,and performance that can be controlled by a push button.
I have my lockup set at 35 mph, a very conservative normal mode, and a very aggressive performance mode.
this gives you the best of both worlds, economy and power.
I'm pretty sure 00-04 had the same computers
01-13-2010, 02:58 PM #12
I would say at least 4000 call comp cams they will ask all of your info and they will tell you what stall you will need.
01-14-2010, 09:44 AM #13
- Oct 2007
- NC
SOM- 1998 T.A.
At the least a 4000 and 3.73's would help too...
01-14-2010, 10:00 AM #14
For Sale: TR TRak cam and TCI 3500 stall torque converter
By UTVols98 in forum Parts For Sale / TradeReplies: 21Last Post: 06-11-2010, 10:48 AM -
How does the stall converter behave, does the car move below stall speed?
By 99bluebird in forum Automatic TransmissionReplies: 15Last Post: 07-02-2007, 01:49 PM -
2800 stall torque converter
By jinouk67 in forum New Member IntroductionsReplies: 11Last Post: 05-22-2007, 10:17 PM -
Is It smart to put a 4000 stall torque converter
By kams95ss in forum Automatic TransmissionReplies: 4Last Post: 02-06-2007, 03:41 PM -
3500 Stall Torque Converter
By mitch98ss in forum Parts For Sale / TradeReplies: 2Last Post: 10-29-2006, 08:04 AM
