Thread: 02' steering column
08-17-2012, 04:22 AM #1
- Jun 2012
- florida
02' steering column
The area around my tilt seems very loose. If I grab the wheel I can move it side to side a bit. What is required to fix it?
08-17-2012, 05:12 AM #2
- Jun 2011
- Branchville, NJ
Sounds like a very worn bushing.
08-17-2012, 06:08 AM #3
- Jun 2012
- florida
tilt
I remember in the older models there were some plastic pieces to be replaced and tightened up.
08-17-2012, 06:15 PM #4
Unfortunately, GM columns have been known to loosen up over the years. Our '85 Monte Carlo SS was terrible when we bought the car a few years ago. You actually had to hold the steering wheel up to engage the ignition. Not sure if the F-body columns have the same issue, but on the earlier column it was a set of torx head bolts about midway down in the column. Had to take the whole upper section apart and even then you could only access 3 of the 4 bolts. I can check my books if no one else posts up a reply.
Steering Column
By Fterr99ss in forum Camaro / SSReplies: 2Last Post: 10-07-2010, 04:01 AM -
Question: Steering column
By REVNORR82 in forum Suspension and HandlingReplies: 3Last Post: 10-06-2010, 11:16 AM -
97 GMC Steering column
By 1998 T/A in forum Parts Wanted / TradeReplies: 2Last Post: 04-24-2010, 08:48 AM -
Will this steering column fit
By shanepatrick1230 in forum Firebird / WS6Replies: 0Last Post: 09-15-2008, 05:23 AM -
Need steering column
By los41682 in forum Parts Wanted / TradeReplies: 3Last Post: 06-13-2006, 07:33 PM
