Results 1 to 11 of 11
Thread: Need to raise back end
11-28-2011, 03:02 PM #1
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
I lowered my car several months ago and not that the springs have settled the back end has dropped about 1/4 to a 1/2 inch more than i wanted. How can I raise the rear back up this amount? Do they make spring spacers and if so where can i buy them?
11-28-2011, 04:03 PM #2
you could try the heater hose mod on the springs.....not sure if that'd give you enough but it'd probably give you a quarter inch.
11-28-2011, 04:15 PM #3
go to your local parts store and look in the towing section. There they have this rubber blocks that you can insert in between the coils to give it a small lift. that should help you out.
11-29-2011, 12:16 AM #4
+1 on the Heater Hose Mod on bottom of spring . Be sure you keep the upper rubber isolator in place.
Sent from Motorola ATRIX 4G on Tapatalk2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
11-29-2011, 03:23 PM #5
- Nov 2009
- North Carolina
what does the hose mod do and how is it done
11-29-2011, 05:48 PM #6
it's supposed to be done to lower the height of the rear. You take the isolator out of the top and then slide a heater hose up on the spring and put the spring back in.....that will give you a little drop in the rear. In your case you could leave the isolator in place and slide the hose over the spring and it may give you a little bump in height. Probably not a lot but maybe a quarter inch or so.
11-30-2011, 03:25 PM #7
- Nov 2009
- North Carolina
will the heater hose not wear out over time or compress?
12-01-2011, 05:03 AM #8
- Dec 2005
- Laurel, Maryland
I run stock rear springs and the heater hose mod...I love it.
If you still have your stockers, I would do that.
12-01-2011, 08:59 AM #9
12-01-2011, 10:51 AM #10
12-01-2011, 02:29 PM #11
- Nov 2009
- North Carolina
Going back with stock springs would raise me up more than i want i think ill try the heater hose mod and see how that works out
Help me raise some money...
By Spikito in forum Almost Anything GoesReplies: 1Last Post: 02-02-2010, 10:29 PM -
For those who raise boys
By Sarge in forum Almost Anything GoesReplies: 28Last Post: 03-18-2009, 01:45 PM -
Does NOS Raise Your Compression
By 99Ls1fever in forum NitrousReplies: 64Last Post: 07-15-2008, 08:13 AM -
Pay too much and you could raise the alarm
By CaptainCaveMan in forum Political / Debate ForumReplies: 17Last Post: 06-05-2007, 11:48 PM -
I just got a raise!!
By Hi-Po in forum Almost Anything GoesReplies: 8Last Post: 04-28-2007, 09:39 AM
